-   -   Why won't my engine start back-up? (http://www.hotrodders.com/forum/why-wont-my-engine-start-back-up-220610.html)
LilHerm 06-16-2012 06:01 PM
This has happened several times and I can't figure it out. After running at good operating temp, I will shut it down. I will turn right around and try to re-start it, I won't turn over. I don't pump the gas but it still has the "flooded" attitude. Literally takes a couple minutes for it to finally fire-up.
Timing problem? It runs great
Carb?
I'm at a loss! Suggestions?
BBC 396 w/ Edelbrock 1407/750cfm
Grease_Fever 06-16-2012 06:23 PM
Timing is a possibility. You can advance the timing to a point that it will run great, but it won't turn over to restart. Try slowly backing off the timing to see if that works. Obviously, you'll want as much timing you can get, without detonation and the ability to restart.
LilHerm 06-16-2012 06:30 PM
Thanks for the advice. I will check it out!
Mojo56 06-16-2012 07:44 PM
"Won't turn over" means the starter isn't working..."won't fire or won't start" or "cranks but won't start" are totally different...
Is the carb getting so hot that the gas is boiling in the float bowl? Vapor lock?
