why would great running carb just start acting up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2006, 10:59 AM
bullheimer's Avatar
NEVER use credit cards!
i have had this holley 600 vac/sec on my 350 for a zillion years and it's always run great. it is the kind that has a metering block for the secondaries, with no jets. i was getting some backfiring before, changed the coil and a broken wire, and it pretty much fixed it except for when i'm just puttin down the freeway, not under any kind of load, and it will just hiccup, backfire here and there and then, this is the strange part........
i pull out the choke alittle bit and it runs fine! it must be running too lean right???? i already rebuilt my carb and changed my fuel filter and fuel pump. could it be something is stuck inside my carb? would changing the metering block out to one with jets possibly cure my problemo???? i am close to junking this holley anyway cause of my crappy mileage, but the rpm intake is a square bore design, so i cant really put a Qjet on it cause the adapters are so crappy. can i? what should i do?
Old 04-12-2006, 11:16 AM
I use a standard Mr. Gasket Q-jet adapter on my engines and they work just fine. I bolt them on the manifold first and smooth the entry and remove any ridges and mismatches before installing the carb.
Old 04-12-2006, 01:25 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
When I have a carb that suddenly quits running right I check a few things; fuel filter, dirt in a jet or orifice, a stuck float, or (in the case of a Holley) a stuck or malfunctioning power valve.
Sometimes tapping on it will release a stuck float.
Old 04-12-2006, 01:39 PM
bullheimer's Avatar
completely rebuilt the carb about 2 months ago. i'm trying to get this pig to run right.
Old 04-12-2006, 01:49 PM
You mentioned it ran fine before but also that you rebuilt it. What was the reason for rebuilding and has the problem only been since the rebuild?
Old 04-13-2006, 02:56 PM
bullheimer's Avatar
backfiring and stumbling all of a sudden on the way home from somewhere, when it ran great there. i have changed coil. checked my unilite etc etc. i just checked my spark. it also doesnt want to start when it's cold. my spark is very small like not high enough voltage. i dont know if my voltage regulator on my unilite is messing up, or if my coil sucks. i am thinking again of ignition problems. i am about to chuck it and get a HEI
Old 04-13-2006, 03:31 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
A muddauber made a nest in your fuel line and now all of the mud is in your carb.
Never leave your parts open to the air in Florida
25 Year-old Carb, rebuild or trash? Arcuden Engine 6 07-31-2005 09:42 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 02:10 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 06:44 AM
Qjets Ain't they great Mertz Engine 18 08-16-2002 01:53 PM
Broke in and running GREAT 56wagon Engine 6 07-25-2002 04:25 AM
