whys doe's my battrery keep dying? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2010, 09:03 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I can't seem to figure this out but if I have my car parked for a week or so &I go to start it it'll be dead.It all started after I dropped the new motor in last February, I put it in drove it a few times then parked it&2 weeks later it was dead.Didn't really drive it again for a few months drove it once or twice would park it&it would go dead a week or so later.I replaced the alternator, got a bigger battery &put in a high torque starter, disconnected the tach&stereo &no luck!PLEASE HELP!I'd love any advice.
Old 10-15-2010, 01:39 AM
35terraplane's Avatar
why does my battery keep dieing
well it keeps dieing because you are more than likely pinching a wire that you can't see. when you changed the engine you either pinch one or scraped on that is shorten or taking a slow draw from your battery. your you have a a loose wire somewhere you will have to go though all the wires around the engine that were removed. I would think that it would blow a fuse unless it's one of the hot wires in the IGN circuit, they don't have many fuses, you did not say what kind of car or year,stock wiring and fuse panel, or after market.
Check for wires then post the other thing.
Later 35terraplane
Old 10-15-2010, 03:58 AM
It seems like you may have a parasitic drain on the battery. There may be something as small as a glove box light on. I would retest the battery and alternator at Autozone. If that is working properly then it has to be a drain. There is a way to test it with a hot light tester. Although you will have to pull the each fuse and see if the light goes out at the battery. Once the hot light goes out then check what that fuse controls and it will narrow down your search. I can't really remember off the top of my head how to set up the hot light on the battery. I may experiment at home on my truck to tell you or maybe someone else has heard of doing it like this. Hope that helps. In the mean time just take off the positive off the battery while it sits until you figure it out.
Old 10-15-2010, 04:51 AM
Charge it and then disconnect the battery and see if it happens again.. If no good, charge it and disconnect the alt and see what happens..
I would go after something you recently installed because it's a new problem.
Old 10-15-2010, 07:31 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi CTKid,
Have the battery charged then load tested. If it checks out Ok, then disconnect the neg cable & put a test light between the neg post & the cable. If the bulb is very dim that could be normal A clock in the radio, but if it's more then just a faint glow you'll need to check the fuses one at a time as stated in a previous post.
Rich
Old 10-15-2010, 07:22 PM
Rexnfx's Avatar
It is hard to tell exactly how much current is running through a test light A meter is the way to go, but you gotta be careful, or you will be buying meter fuses or cheap meters. Search parasitic draw on the net. There is much info on this. GL
Old 10-20-2010, 03:43 AM
hi everyone,
I think every battery has its expiry time I don't know the technical terminologies, It battery starts getting discharge very fast, It means your battery reached the time, when it needs new solution (sometimes people us boiling water for it which may leads to early discharging of battery) in it.
Thanks
Old 10-20-2010, 06:54 AM
bubbahotep's Avatar
Do you have an msd or similar type ignition system that is wired to constant 12v? I've seen them drain batteries cause they're hooked to 12v constantly, you'll need to reside them to a switched 12v that's off when ignition is off
just review your entire electrical system and see what's connected to 12v all the time. Unless your car is computer controlled nothing needs 12v when car is off.
He posted it was a new battery
buy a cheapo meter it won't matter. With the car off, put meter on amps setting and put it between your battery gnd wire and chasis (you'll have to remove the battery wire from the car battery). The current draw will be low but you'll see it. If the meter explodes you'd drain the battery in a day or less. Since it takes a week it's a low draw so the cheapo meter is ok.
Old 10-20-2010, 08:18 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
kill switch............
Old 10-20-2010, 10:58 AM
Battery keeps dying
I agree with shine, I won't wire a car without one. Although that still won't fix your small drain, which will sooner or later cause the battery to go bad from recharging.
35terraplane
Old 10-20-2010, 12:09 PM
two cups of tea
Wiki Edits: 2
I'm gonna go buy a meter tomorrow, I went through all the wiring&rewraped everything,stuck a test light between the cable&battery&the light was bright did all that a month or so ago,Ill try everything you guys Said&post the outcome.Thanx
Old 10-20-2010, 04:53 PM
EOD Guy's Avatar
You def have a drain, you might consider..... disconnect the engine/computer harness, let it sit for a week, ck the battery, if it's flat you probably have a crossed wire in your harness, grounding the system out which results in the flat batt (as you decribed above) you'll have to break out the books and chase each wire to ensure it goes where it's supposed to etc.... as, mentioned above I'd start with the dizzy supply wire. If you can't locate the drain..... Auto Zone or Advanced Auto sell a battery disconnect switch for 13 bucks, hook that between the neg cable and the chassis ground, not a perm fix but a soluition untill you figure out where the drain is coming from.
Old 10-20-2010, 07:10 PM
two cups of tea
Wiki Edits: 2
I think I may have to pull my dash off again because when I hooked up my tach I ran some wires through there.
Old 10-20-2010, 09:04 PM
mud.man.rj's Avatar
Elect Gremlins
Buy a digital meter, hook up to neg and pos battery posts, put meter whwre you can see it from drivers seat. Note what meter reads (ign off ) pull one fuse at a time watch meter each time you pull a fuse if the meter voltage rises their was a current draw on that circuit. That is the current draw, but use your head on each fuse you pull and replace make sure it is not for something that is on like interior light, clock. Just read each fuse. You can do the same with under hood wiring to see if current draw on any wires you can physically unplug one at a time. Good luck.
Old 10-21-2010, 10:28 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
[QUOTE=mud.man.rj]Buy a digital meter, hook up to neg and pos battery posts, put meter whwre you can see it from drivers seat. Note what meter reads (ign off ) pull one fuse at a time watch meter each time you pull a fuse if the meter voltage rises their was a current draw on that circuit. QUOTE]
Don't you mean;
set the meter too read AMPs;
remove the neg wire from the battery;
connect the meters NEG probe too the NEG post of the battery;
connect the POS probe too the wire you removed from the battery;
read the draw that way.
Hooking the meter acrossed the POS and NEG battery terminals will always read voltege.
dying seats and carpets dusterbd Interior 5 11-19-2009 04:30 PM
battery dying lemans'n'gal Electrical 2 04-14-2009 09:49 AM
Dying Cad? OneMoreTime Engine 6 11-17-2005 05:14 PM
84 S-15 keeps dying lonewolf3197 Engine 4 01-12-2005 11:13 AM
Are machine shops dying off? Jmark Engine 32 09-12-2003 05:36 PM
