wich coilover - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 08:52 AM
Last journal entry: some stuff
wich coilover
I've mounted an rear axle under the frame of my '37 Chevy sedan using a four-bar system. I know need to order a set of coilovers. Does any one know wich type (pressure) I need to take so I have comfortable ride?
Old 08-23-2012, 10:34 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You will need to know the weight of each axle in order to get close on the spring rate and shock valving..i like the ones that have adjustable shock valving and the springs are easy to change and not all that spendy should you be off and need to adjust..
Sam
Old 08-23-2012, 10:50 AM
It's 1500 pounds on the front and 1435 on the rear axle.
Old 08-23-2012, 02:06 PM
We have a real nice spring calculator >> Spring Rate Calculator Ridetech – Tech
coilover adj. HOTROD41 Suspension - Brakes - Steering 1 08-01-2009 12:20 PM
Coilover covers vendettaautofab Suspension - Brakes - Steering 2 07-19-2008 07:59 PM
coilover shocks ibarodder Suspension - Brakes - Steering 1 01-11-2007 02:22 PM
Hi I'm coilover coilover Introduce Yourself 3 07-23-2005 12:20 AM
coilover shocks jeffbilliekatbrett Suspension - Brakes - Steering 1 01-04-2002 05:41 PM
