Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wich model frontclip
Old 08-18-2005, 06:12 AM
astroracer's Avatar
astroracer astroracer is offline
The thing in your favor here is that GM uses the same bearings, seals, bushings and ball studs throughout most of their car lines. You will have to pull the bearings to compare but they have part #'s on them that your parts house can cross-reference.
I would also suggest cleaning up the spindles and pulling the casting numbers from them. This way you will have something we can physically "match" to determine what you have.
Mark
