Wide band AF. Holley carb adjusting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2013, 02:21 PM
staleg's Avatar
Last journal entry: Hand brake
The '34 Roadster works pretty well. Ignition is adjusted. It's easy to start, pulls evenly and good, no stumbling. The idle is maybe a little high, even with the adjusting screw all the way out, but all in all the engine works well.
But the AF ratio is way too rich. Crusing around 12-1500 rpm shows 12-12,5:1.
QFT Super Street (Holley based) 650 CFM DP carb.
Engine is a Chevy small block mainly standard except air gap intake, headers and 2 x 2,5" exhaust, straight thru mufflers.
6 speed trans.
What do you suggest? Lean down the primary jets a bit?
If so, how much? 3 steps?
Old 06-28-2013, 02:40 PM
Banned
first lean down your idle until it stumbles at transition, then go back just a hair to cure the stumble. then lean your primaries, but only go 1 step at a time. for cruise 15:1 is about ideal, but sometimes its needs to run richer with a carb to compensate for uneven distribution.
Old 06-28-2013, 02:48 PM
staleg's Avatar
Sounds like a good start. Thanks
Old 07-10-2013, 01:33 AM
i put a $20 narrow 02 gauge, and an old spare 02 sensor I had laying around in my car... best $23 I ever spent (forgot the $3 for the 02 bung)
I had to go down something like 6 or 8 jet sizes to get my holley 650 (vac secondary, dual feed) to run 14.7-ish:1 at cruise.
1200-1500 rpm cruise seems a tad low.. what ground speed are you doing that at? 55mph with an o.d that wouldn't surprise me much :>
Old 07-10-2013, 10:27 AM
Slammedsi's Avatar
6 speed trans.
Been wanting a wide band. What brand are you using? And are you runing only one sensor in one side of the exhaust.
Old 07-11-2013, 04:28 AM
staleg's Avatar
Only one sensor, yes.
The brand is AEM:
http://www.summitracing.com/parts/avm-30-4100
AF gauge to the right with vacuum gauge left of it. Good information for both ignition and carb adjustings.
Old 07-11-2013, 04:37 AM
Andy79Z28's Avatar
air fuel
I have 2 AFR wide band meters. My problem is that the O2 senors do not last. I use leaded race fuel and the O2 sensors clog up right away and go bad. Any suggestions?
Old 07-25-2013, 07:51 PM
Andy79Z28's Avatar
Guess no one has an answer for my last post......
Wide Band A/F Tuner Controller SSedan64 General Rodding Tech 1 09-01-2010 06:08 AM
Wide band or narrow band A/F...? staleg Engine 6 08-12-2008 02:10 PM
adjusting floats on holley carb inquiring_mind2 Engine 1 04-24-2008 09:29 PM
looking for wide band sensor pt no. 0258007057 sc2dave Engine 9 05-10-2007 10:15 AM
Anyone use this wide band A/F meter? dirtydave Engine 5 05-15-2005 08:35 AM
