Wide band or narrow band A/F...?
I'm planning to buy an O2 sensor with air/fuel ratio gauge for my carburated motor to help me dial in the carburetor.
Do I need a wide band kit for this? What will the wide band kit give me that the narrow band won't? Last edited by staleg; 08-07-2008 at 01:43 AM. Reason: Posted the same before, Sorry. |
I don't think you'll need a wide band sensor to set up a carb. You should have all the info you'll need with the standard O2 sensor. A wide band sensor is more of a necessity when you're dealing with fine tuning emissions on a modern, fuel injected, heavily pollution controlled (for lack of a better term) vehicles. BTW, strictly speaking, an O2 sensor and an A/F (air fuel ratio) sensor are two different things. They're kissing cousins, but A/F sensors do work a little differently and cost a lot more money
look at the narrow band sensor and wide band sensor charts on the right on this article....
http://www.fordmuscle.com/archives/2...tout/index.php the "wide band" sensor name is a abbreviation/slang for:wide range scale of accurate A/F ratio value readings.... which you need for tuning WOT on a hot rod |
Check out this website:
http://www.innovatemotorsports.com/ I have the wide-band LM-1 meter, as do others that post here. Plenty of info on the website... Steve |
Thanks for the inputs all of you!
I totaly agree that he old fashion way that KA_67_/2 mention is app 300$ cheaper, but I'm relatively new to all this, so I figured an air/fuel gague will be of good help for me the day I start to dial in the QFT 650 DP carb. |
I started using an LM1 recently and cannot imagine tuning a carb without it anymore. Plug reading and timed runs are a waste of time that you will not have to do anymore once you have one...
They're also great to test and diagnose all kinds of carb problems. For example, I was able to diagnose sticking primary rods on my buddies Q-jet, just by driving around with his car while watching the readout. |
| 10 ft wide garage doors.............. | poncho62 | Garage - Tools | 3 | 08-27-2007 06:03 PM |
| Questions about wide wheels and fender flares | tcruise | Body - Exterior | 5 | 06-09-2006 05:50 PM |
| tires, how wide can I go? | 29whippet | Suspension - Brakes - Steering | 2 | 04-13-2005 01:39 PM |
| What car has a 9 in ford less than 64 inches wide? | BillyBob1950 | Transmission - Rearend | 2 | 02-12-2003 08:21 PM |
| wide whites | pichoboxing | Hotrodders' Lounge | 4 | 07-07-2002 01:33 PM |
