wierd engine ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2012, 05:35 PM
wierd engine ID
Im have 327 that is supposed to be out of a camaro in 67 pickup. The Id above the water pump is V0916ESD. I tried looking it up on Mortec's database but couldn't find anything. Any help would be appriciated.
Old 11-04-2012, 06:58 PM
wierd engine ID
Here is all I found. V- Flint(engine),09-Sept., 16-day of month, ES-1967 327 sp. hi. perf., HD clutch 325hp, 4 barrel, Chevelle. There was no code listed as ESD.
Old 11-05-2012, 04:26 PM
It is weird. A guy finally came with a crane to pull the motor. I got to read the ID on the back of the block and it was 14010207. It showed to be a 80-85 pickup motor with 4bolt mains. The the oil pan has been off is known to be a 4 bolt engine. The heads are 882's also.
Old 11-05-2012, 05:56 PM
hcompton's Avatar
Old & Furious
882 heads on oe 327? That dont sound right. They usally have older style heads.
Looks like its a truck 350 by the numbers. Date code does not match up problaly need to put some white on the numbers to see them better. I think 327 all start with 3 if im not mistaken.
Could have been a 2 bolt 305. Not bad to have a later 350 block. Should be a strong runner over older 327 without all the updates. Just little less cool factor.
Old 11-05-2012, 08:23 PM
DoubleVision's Avatar
Goes to show you can't believe everything your told. Another dead giveaway other than the casting number confirming it is the 327 never came with 4 bolt main caps. However someone could put a large journal 307 or 327 crank in a 350 4 bolt block and there you have it.
Old 11-06-2012, 02:15 AM
we pulled the heads and it has a 3.5in stroke. The date code was cleaned up and it was F not an E showing it to be a 94 pickup with tbi. When he got it had a 2 barrel carb. The engine was pretty freshly rebuild. Still had honing marks in the cylinders. Too bad it isn't a roller block.
The motor ran good, but the trans lost 1st and Reverse. and the rear end grenaded. While it is apart he wants to some extra power. It is a friend of mine. I have him talked into vortec heads, a summit 1103 or comp 268he cam to go with 3.73 posi. It was a 3 on the tree. He wants a 5 speed manual.
His goals are healthy idle, enough power to run with most modern cars, while still being comfy to drive for 40 miles should he want to take the wife out.
Thanks for the patience.
Old 11-06-2012, 02:47 PM
Crummy heads, great block, so what's next? Not what they told you but not a bad place to build from.
Bogie
Wierd Engine Code for3300 Hotrodding Basics 5 03-23-2012 12:54 AM
1987 chevy stepside 305v8 engine runnign wierd nathanr Engine 1 12-16-2009 05:59 PM
wierd engine bearings ajh86 Engine 19 12-12-2006 09:50 PM
Engine wont shut off, really wierd ataririder Engine 13 01-27-2004 11:10 AM
wierd engine tuning problem dusterbd Engine 6 05-12-2003 08:46 AM
