wierd hesitation is it carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2006, 06:38 AM
A week ago I had my tranny rebuilt. it seems to be working great good hard shifts. But when I am sorta coasting along at 30 ish and I give it a little gas it seems to not want to move. Its almost as if it is bogging down or something. I think the tranny is shifting ok. it almost seems like its getting too much fuel or something. There is this rod that looks like a bolt in a case with a wire attatched to it. The bolt part goes up to the throttle linkage part but it isnt touching it and doesnt move when i give it gas. the car is an 88 caprice with a sbc 350 and 4barrel carb. I dont think the tranny is upshifting on me but thats almost what it seems like. As if i had a stick and up shifted too early. It just sounds odd I hope i explained it good its not easy to describe. If someone could atleast give me a direction as to what i should be looking at. As far as carb or tranny or who knows what that would be great.
Old 11-09-2006, 06:49 AM
Sudden Psycho 31's Avatar
it is kind of hard from the part explaination, but sounds like your downshift cable is not hooked up, or is not adjusted correctly.
your downshift cable, manually pulls the transmission to a downshift position when given enough pedal.
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 02:10 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
edelbrock carb Vacuum problem? 75400truck Engine 16 10-03-2004 09:29 PM
Carb. hesitation Slant3 Engine 4 08-22-2004 01:59 AM
