wierd markings on block. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2013, 09:21 PM
I hope you can see them in the pic, I highlighted them in yellow but it did not work as well as I hoped. I found these odd markings on the underside of my 350 block. each cylinder has a letter stamped near it. also each corner of each cylinder has a 0 next to it. almost looks like a degree mark. I think it may be from the machine shop but can not say for sure. has anyone ever seen something like this or have an idea of the reason?
Old 08-19-2013, 11:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Those are factory stampings indicating either main bearing sizes or bores. They have no relevance outside the factory.
Old 08-20-2013, 07:03 AM
BOBCRMAN@aol.com's Avatar
At the engine plant. The bores are size determined and correct size piston is assigned to each bore.. Pistons are marked with a letter code for size (lots of H K L sizes). The pan rail is marked for the correct piston. The block continues its journey down the line with pan rail up. As the parts move down the line, a worker loads the correct letter piston/ring/rod assemblies in carriers that match the bore position.
Old 08-20-2013, 07:08 AM
carolinacustoms's Avatar
Automotive Extraordinaire
So I guess it was cheaper to use 4 different sized pistons than to machine 8 same sized holes?
Kelly
Old 08-20-2013, 07:15 AM
Kelly
It's called mass production.. Tooling wears and STUFF happens.. Real world conditions..
Old 08-20-2013, 07:21 AM
I thought it was after market because I have never seen marks like this. when I found them I got a little worried thinking it was from blue printing or it was some special code. I had to stop working on it until I found out. thanks guy's.
Old 08-20-2013, 07:30 AM
Sorry if my post was taken the wrong way, I did not intend any offense or to come across as a smart *****. I am all too familiar with mass production and their "adjustments" for tooling and etc. Have great day.
Kelly
Old 08-21-2013, 05:12 PM
Richiehd's Avatar
JS-70
Kelly
I got a chuckle out of that remark, I was thinking the same thing myself!
sbc markings chevyman420 Hotrodding Basics 18 02-29-2012 09:15 PM
Block Markings rj57 Engine 3 04-08-2010 11:22 AM
Markings on a sbc 3970010 block Mad4Dad Engine 3 08-12-2008 11:35 AM
Rocker markings?? snakey Engine 7 04-24-2006 01:32 PM
Where are the timing markings? Dubz Hotrodding Basics 7 02-14-2004 10:38 AM
