wierd oil presshure readings - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2006, 06:02 PM
hello all i have a 1971 prostreetvega wagon with a sbc 406new motor 10.75 compresshion comp camsolid roller xr280rdart heads 64 cc chambers 208 valves 750 demon carbsuper vick intake 1 inch spacer 35 000 stall hope thats enough info anyways have a lot of issues with lots of crankcase presshure finally had to get breathers with nipple to a catch cantosolve weeping breather problems oh also i have a millodon 6 quart pan gm stock hi volume pump so my prblem seems to be my oil presshure seem to drop over 32 hundred rpm then when i back off goes back to 50 psiidels at 20 psi hot
oh and also i am running the really really short oil filter did that cause ithought it would keep filter further away from headers cold start i have 60 psi average cruise when hot 45- 50 when i get up in rpm will go down to 20 got me baffeld maybe gauge auto meter direct feed copper line any ideas welcome oil is clean 20 w 50 tons of oil in top end car is all solid mount could the vibrations have screwed gauge grabbing at stars any help welcome if more info needed plz ask
Old 10-09-2006, 06:11 PM
I wonder what kind of oil pan/pick up tube
Old 10-09-2006, 07:24 PM
Known traffic menace
I was thinking pickup tube myself, was it welded on? Are you running a PVC valve with the breather,,Hope that maybe this helps,,Perry.
Old 10-09-2006, 08:57 PM
hey thanks for reply guys yes the pick up tube is welded and no there is no pcv valve just to mechanicely fastened billet breathers with 2 half inch hoses goint to a one quart jaz catch can ty again 4 your thoughts
Old 10-10-2006, 07:34 AM
Is the high volume pump draining the sump? (unlikely), have you installed a top end restrictor? In my experience the most common cause of a pressure drop hot is too much clearance between the cam and cam bearings. Generally if the crank/mains are worn the pressure drop is constant , same for pump problems. Good luck, Ian.
Old 10-10-2006, 07:44 AM
What kind of oil pan? How far is the oil from the crank? Do you use a windage tray? Scraper? How far from the pan is the pickup?
Old 10-10-2006, 09:49 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Change your filter first. Try a Wix 51060
Old 10-10-2006, 02:33 PM
zephyrc's Avatar
i had exactly the same problem with my 408 sbc, i changed the pump twice, checked every bearing, changed the filter. i had good oil pressure at idle and at cruise but when i accelerated from say 3400 to 4000, the pressure would drop by around 10-15 psi. the problem turned out to be an oil level issue, with the longer stroke that the 400s have ,the crank was getting into the oil and aerating it on acceleration. the answer in my case was to lower the oil level by 2 qts and the problem went away.. george
Who makes the best oil??? classic_chevy_guy Engine 28 02-21-2013 09:04 PM
Oil Filter relocation kit... jmbjs Engine 4 04-11-2006 09:15 AM
Oil Preshure ve3ham Engine 9 10-28-2004 03:36 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 01:47 PM
Low idle oil pressure chuckellison Engine 4 03-03-2003 08:20 AM
