Wierd Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2004, 03:30 PM
Wierd Problems
I finally got my engine runnin smooth but a series of problems just occured the motor runs hot, when I shut the door the engine cuts off, when i place the clock fuse in the car it will not start up, and it back fires does nebody know how to fix this?
Old 04-17-2004, 04:15 PM
DoubleVision's Avatar
It sounds like you have more than a few electrical woes. when you close the door you kill the interior lights which closes the circuit, if that shuts the car off it sounds as if it`s connected to the Ignition source and it shouldn`t be, go back over all your wiring and get it straitened out, then you can sort out your overheating problem.
Old 04-18-2004, 12:34 PM
The only problem im having is that the motor back fires after I run it for a while it sounds like a gun shoot. Neway to fix?
