Tick
[size=3]Doc Here
The wrist pin would be a double knock (X2 the rotation) and medium in tone, The rod would be deep tone , and single in nature becoming more pronounced under load... From what you describe, Dosen't sound like either. Try adjusting the lifters on that side, a loose intake would probably tick, and miss at rpm increase. If you don't want to spill oil all over, get an old valve cover from the bone-yard or buddy's junk pile, and layout some guide lines about where the adjusters are, drill a hole big enough to get a metal cutting sabre saw blade into it and cut out your lines...just use that while adjusting your valves, If you get some splash, cover the ones your not working with, with duct tape as you move along. If you can't adjust it out, You may have a clog..pull the lifter and clean or replace it (them). Clean and change the oil and filter. Hope it helps! Doc [/size]
Aftermarket Solutions Electronic & Electrical Innovations |
Just decided to adjust them all...(Man I hate high compression engines!)
It seemed to have a few just on the loose side, and a few on the tight side. Glad I decided to adjust them. ![]() I'll end up taking it for a cruise tonight. I'll fill you guys in on what I find.... If it ends up bing a lifter, then I'll just have to go out and get that cam I wanted.
FOUND IT!!!!
I adjusted my valves, and took it for a ride. It idles a little better, seemed to run better, abut the ticking showed up again. I listened and then realized that a few bolts on my exhause manifold were loose. IT WAS AN EXHAUST LEAK!!! Now I just have to get longer bolts as they are way too short. The heads grab about 3 threads, so needless to say it is an easy fix...just hard to troubleshoot. Thanks for the help doc...car runs better now!
Great!
[size=3]Doc here
Glad to hear you found and fixed it... And that it was an easy fix! Thanks for posting back and letting us know! Might help the next guy... Doc [/size]
