wife's die hard beretta - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2002, 01:26 PM
Post wife's die hard beretta
Here's one that recently has me in a tied fit,my wife's car,94 chevy beretta has developed a mind of it's own. the problem is,at times the headlights will dim,not alot though,and the speedometer acts like an tachometer being erratic and stock sound system LED readout goes out,but no "service engine" light comes on,it does work properly(so far)is there a nome under the hood who likes pulling pranks on me? Thanks Guys....
Old 11-23-2002, 02:24 PM
4 Jaw Chuck's Avatar
Post
Check all your grounding points first for bad contacts and corrosion. Also check all the connectors under the hood for the same, considering your vehicles age it is ripe for these problems to happen.
That should get you started.
— Han Solo
Old 11-24-2002, 06:42 AM
Post
Well guy(s),did that,checked ground points & connectors,seems everything is fine there,any other suggestion that could be applied? Spend a small fortune on meters and cont.checkers.I need a nome whacker i assume.. <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 11-27-2002, 09:15 PM
Post
Same *******,different day;Hey ya guys,I did the checks on ground points and alls well there.Is there a possible chance that the alternator is not putting enough output power at idle speed to keep the sensors readings inline? It became a choice between battery and alternator,price difference...48.00 for battery....190.00 for alternator.Would a bench test show the output at idle rather than at full speed which i believe is how they do test them? Thanks
Old 11-27-2002, 09:31 PM
Post
God help you if it is a harness problem, I would definetly check the output of the ALT and the battery first. How about the fuses? Seen a few of those over the years that look fine on the outside but fail a continuity test...intermittently. Since this all seems dash related I would narrow the focus down to these components, dash clusters are not made the way they used to be either. You might want to go over every exposed wire in the engine compartment and check for wires with abraded insulation and connectors that might have corrosion on the contact faces, a few ohms here and there adds up quickly.
Does it do it over railroad tracks? A wiggle test of the harness might be in order too.
I will pray for your soul. <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
— Han Solo
Old 11-28-2002, 02:00 PM
Post
God Bless ya Brother need all the prayers that can be delivered...lol. But seriously.Thanks for the tip there 4jaw,That could be the start of something other than more problems.But will do a batt & Alt. check.Did the connector sites,they was in good shape,but as a precaution, I cleaned them good and dielectric the whole bunch under da hood.So comes THE real test...thanks again guy,will keep ya posted,.....If I don't mistake it for a turkey first(BLAM-BLAM)
Old 11-28-2002, 06:57 PM
Post
Had a simular problem with a Ford work truck.
It turned out to be that -neg- cable looked fine ,but from the factor they also grounded the body midway down the same cable with a clamp and a metal screw . Screw rusted out with age , and only grounded some times. 5 minute fix =2 weeks of same problem scratching my head.
CRAIG
Old 12-02-2002, 09:03 AM
Angry
Hey guys just wanted to let you know the critter that has been causing this problem, has been the rear window defogger switch,(after tearing 98.99% of the dash apart),all the time she had the car,it never worked, now it works prettier than you please but it's interfering with other working Acc. in the car....grrrrrr..oh well, meters keep traveling on <img src="confused.gif" border="0">
[ December 02, 2002: Message edited by: bullit66490 ]</p>
Old 12-08-2002, 02:38 PM
Wink
Hey 4 JAW CHUCK,Dang it dude,I must appolgize to you for not thanking you on this issue,(will stand in coner for day).... Anyway have this taken care of, and thanks again for pointing me in the right direction.I think someone else said something too,if I forgot ya,I'll stay in corner twice as long...lol. Anyway,Thanks guys. bullit <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
[ December 08, 2002: Message edited by: bullit66490 ]</p>
Old 12-08-2002, 05:18 PM
Post
Glad you found your problem, you don't have to stand in the corner...but we do need someone to mix drinks? Do you know how to make a gin and tonic?
I like mine with lots of gin a twist of lemon and you can just stand the tonic bottle near the glass for looks, fools the wife. :p <img src="graemlins/drunk.gif" border="0" alt="[drunk]" />
— Han Solo
Old 12-11-2002, 11:09 AM
Thumbs up
LOL...4jaw chuck,tried bartending,got friends too drunk too quick.And BTW?......nothing gets past MY wife.....tried for years..... <img src="graemlins/nono.gif" border="0" alt="[nono]" />
