Will a 14x2" air filter have good air flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2012, 05:31 PM
Will a 14x2" air filter have good air flow?? This is the only one thats fits under my hood.
Old 12-18-2012, 05:47 PM
hcompton's Avatar
Old & Furious
Edelbrock makes a 1000cfm filter that is almost flat and its cheap. I have a c4 vete so not much will fit under the stock hood.
K & N also makes regular round filters in most sizes and they flow a lot more air. Also check out the filter lid every little bit helps.
Hope this helps
Old 12-18-2012, 05:55 PM
Hope this helps
are u talking about the edelbrock pro-flo 1000. if so i heard that they are trash & don't flow good
Old 12-18-2012, 06:12 PM
vinniekq2's Avatar
I had the same problem on my c-3.now I have a bigger hood(see picture)
Old 12-18-2012, 06:23 PM
hcompton's Avatar
Old & Furious
Always works for me. Nothing to it and the bottom is a nice venturi shape. I got to think it flows well. Now if you have no hood room and use this filter just for clearence with no space above ot they will not flow well. But if a normal filter fits the proflow should have clearence. If flow is not right then just change the element its just flat foam so no big deal to make a new pne out pf better filter material. But i think its pretty good from the factory. 1000 cfm is a big number and edelbrock is not the type pf company to post dreamed up numbers.
But if you dont like the edelbrock 20 dollar air cleaner you can get k&n setup
k&n makes a 14x2 round filter and you can get the filter lid to give it some help.
Here is a link to show a picture of one. But i think the price seems high this is just the first grab off the google search.
K&N Filters 66-1101 : K&N Filters X-Stream Air Filter Lid 66-1101
Old 12-18-2012, 06:29 PM
hcompton's Avatar
Old & Furious
Yeah if you want a tall intake in a vette you need a new hood or a hole in your stock one. Torker II and proflow is the next biggest thing that half way works. But really not a soution for big power. Just the stuff that fits.
Old 12-18-2012, 06:42 PM
Are you using a dropped base air filter housing?
ssmonty
ID:	69888   Click image for larger version
Old 12-18-2012, 07:01 PM
ssmonty
yea.. but i have a performer rpm intake & a 1" carb spacer so it sits high
Sharpe air filter still good? jman340 Garage - Tools 1 01-07-2012 07:07 AM
is their a "spark arestor" in my air filter houseing ? joeshovelhead Engine 5 07-01-2009 05:39 AM
Looking for 14" air filter Jmark Engine 6 01-18-2008 11:18 PM
which hi flow air filter mhamilton Engine 8 03-21-2006 07:38 PM
14" air filter Jmark Engine 1 05-31-2004 07:15 AM
