Will a 1976 360 motor fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2004, 12:27 AM
73 Nova Guy's Avatar
FROM MY COLD DEAD HANDS!
Last journal entry: Swinger
Will a 1976 dodge van 360 motor fit into a 74 dart swinger?
It is a original 318 car.
Old 05-12-2004, 02:26 AM
DoubleVision's Avatar
Far as I know it will, the 273, 318, 340 and 360 are all from the same line.
Old 05-12-2004, 06:31 AM
Wiki Edits: 49
Yep. It should bolt right in.
Centerline
Old 05-12-2004, 07:24 AM
stepside454's Avatar
only differance Im aware of is drivers side motor mount, can either by new or modift the 318 one
Old 05-12-2004, 07:47 AM
it'll fit, maybe new mounts
Old 05-12-2004, 12:59 PM
Make sure you re-use the 318 exhaust manifolds if you plan to run exhaust manifolds instead of headers. Van manifolds are probably b-body manifolds not A-Body and the left side will hit the powersteering box as well as not line up with the exhaust pipes.
The oil pan cannot be re-used from the 318 either, so if that 360 has some kind of truck high capacity pan it may not clear the steering linkage.
I think 75 and newer blocks have thin cylinder wall castings which means a .020 or .030 overbore is the max you can go to clean it up.
That 360 is a better choice than the 318, will make great power on the cheap with a good 4 barrel carb and an RV cam. Don't get too wild with the cam if you plan on retaining those low compression pistons or it will be sluggish to respond. .040 thick head gaskets will put you in the 7:8 to 1 range. Will still pull nicely in a dart though, got the same set up in my Duster.
