Will 1998 4-door Civic Side Skirt Fit On 2 Door?plz Help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 05:46 PM
I have found a body kit, that was off of a 4 door, I do know that the front bumper will, and pretty sure that the rear one will as well, but i am not sure about the side skirts. does anyone know? thanks
Old 02-26-2008, 06:23 PM
Wiki Edits: 31
probably as long as the wheel base is the same.. if not, as long as it's fiberglass you could section and shorten it..
Old 02-26-2008, 06:48 PM
Try www.honda-tech.com
Best way would be to take some measurements or search honda-tech to find someone who has already experienced what your trying to do.
I wouldnt wanna put a bodykit on an EK personally. Not my style.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Postive ground but negative coil, strange one Nightfire Electrical 21 04-19-2006 05:20 PM
Carrier bearing preload? Sixshooter Transmission - Rearend 11 11-10-2005 11:35 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
