will a 267 small block fit a suburban? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 04:29 PM
as you can tell from my name i know nothing about cars...i haev a 1985 subrban and the engine went out...i know it has a 350 in it...a friend said he has a 267 chevy small block v8 and it will fit... i just want to confirm this!
Old 03-22-2010, 04:38 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I am sure it will fit but i wouldn't even consider it JMO. They only made those engines like 3 years i think. And a very low HP engine at that small bore just not a good engine IMHO especially for a big ride like you are talking about, Wouldn't consider it at all i would get another 350 or a 400 or even a bigblock. Before i would mess with the 267 engine . JMO
Cole
Old 03-22-2010, 04:45 PM
DoubleVision's Avatar
Eloc just gave you some very good advice. It will gut the 267 trying to carry the weight of a locomotive sized suburban. These engines were made for vehicles that had wheel bases that didn`t exceed a certain limit. They came standard with about 110 horsepower and that was on a good day. If you were to place a small RV cam it still wouldn`t do any good, the 267 is so small a RV cam that idles smoothly in a larger small block is radical in a 267. The next problem is the 267`s small 3.500 inch bore, coupled with its long stroke of 3.480 results in high cylinder tempatures that can burn holes through pistons, the best place for a 267 is the recycler or a boat anchor.
Old 03-22-2010, 04:54 PM
ericnova72's Avatar
More for Less Racer
If you need to get the Suburban on the road cheap the 267 will fit right in place of the 350. It will be rather slow as this is a low performance motor, but it will get you up and down the road if money is a factor. Had a friend put a 267 in a '82 Chevy Caprice Stationwagon in place of a 350, it wouldn't get any speeding tickets but got him around and to work and back 50 miles a day without a problem.
Old 03-22-2010, 05:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You are confirmed- but if you're even considering it, know right now that it will be VERY slow accelerating. Dangerously slow, IMHO.
I'd MUCH rather have a 4.3L V6 than that pos, to be honest w/you.
Old 03-22-2010, 05:52 PM
Yes it is the same externally as the other small blocks. A good friend of mine had a chevy tiltbed with a 267 in it. He hauled enough scrap cars to build a 355 for the truck.The truck actually wasnt too bad to drive,but it was no powerhouse.
Old 03-22-2010, 06:43 PM
Wiki Edits: 31
they were made from IIRC 1979-1981 and produced 115 HP.. they did come in Caprice/ Impalas tho.
Old 03-22-2010, 07:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Think of what a 267 Caprice would run like, towing another 1/2 Caprice, and that would be about like the 'burban w/a 267! LOL
Old 03-22-2010, 07:52 PM
Everything is HAMMER!
If it's cheap, go for it. At least he's kind enough not to lie to you about engine size just so he could sell it to you for more than it's worth.
Old 03-22-2010, 08:29 PM
Wiki Edits: 31
I know. I had a '81 Impala 4dr parts car bought for the engine for $75 and told it was a 350.. IIRC I did have it running and it ran pretty good but when I ran the numbers and found it was a 267 I just junked it..
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
400 small block idling problems 19nova72 Engine 15 04-16-2006 02:53 PM
Small Block Vs. Big Block bfrett123 Engine 3 10-14-2004 05:27 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
