Will a 305 chevy crankshaft fit on a 307 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2013, 06:24 PM
Hi I am new to this site even though I have read it before, here is my question can I use a 305 crankshaft on a 307 engine? The reason why I ask its because I have a 1986 chevy Monte Carlo with an original 305 engine, and a friend of mine give me a 307 engine to rebuilt it and use it I have a new set of head for this built and a camshaft but looking at the crank pulley I notice it's smaller than my 305 so I don't think that my alternator , water pump and ac compressor are going to match any suggestions about what should I do? Thanks for any help
Old 03-14-2013, 06:54 PM
BOBCRMAN@aol.com's Avatar
A 305 crank will fit into the block but nothing else will work with it.
Why not use the 305 balancer on the 307? Also use the 305 front cover. Then the pulleys will fit.
Old 03-14-2013, 07:25 PM
Not easily; the 307 has a stroke of 3.25 inches the 305 has 3.48. Both engines use a 5.7 inch rod so the difference in additional stroke length of the 305 crank to keep from pushing the piston out the top is taken in the 305 piston by lowering the pin position by .115 inch compared to the 307 piston. The 305 piston has a diameter of about 3.735 inch compared to the 307's larger 3.874. This is .140 inch which would preclude finding an oversized 305 piston that would fit the 307 bore and bring with the pin position. You could use the shorter 400 rod (5.565 inches) with the 307 piston for an assembled length that's really close to what's needed. But then the piston skirt gets pulled so low in the bore it hits the crank's counterweights.
So this just isn't practical to do, not saying it can't be done, but that won't happen cheaply.
If the 307 is a pre 1973, it may well bore to 4 inches, then you could make a 350 out of it with the 305 crank and rods using 350 pistons.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
Ferabel73 (03-15-2013)
Old 03-14-2013, 07:30 PM
Thanks for your suggestion, but will the balancer fit from my 305 into the 307 crankshaft ? If it does what about the flywheel would be different ? Or is it the same
Old 03-14-2013, 09:00 PM
As stated the balancers are interchangable, as are thr flywheels
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
Old 03-15-2013, 01:16 AM
Thank's a lot for helping me guy's
Why weren't chevy 307's and 305's used as performance engines? CometCyclone Hotrodding Basics 13 11-11-2012 02:41 PM
305 heads for my 307 small block chevy alexcamaro307 Engine 6 12-23-2010 09:16 AM
307 chevy v8 crankshaft in 75 350 Gideon Engine 8 09-20-2008 08:26 AM
305 heads on a Chevy 307 75Guy Engine 6 04-30-2007 09:58 PM
olds 307 and chevy 305 Fresh469 Engine 7 06-10-2005 01:57 PM
