will 305 trans fit on 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 03:34 PM
i have a 78 el camino with a 350 and the trans went out, iwas going to bur a z28 camaro with a 305 for the transmission but am not sure if they will work
Old 05-25-2008, 06:01 PM
same bolt pattern on back of engine block for the trans on both engines..
Old 05-26-2008, 07:09 AM
If they are the same type of trans (TH350 or TH200, for example) then it's a bolt-in. If the Camaro has a 700R4 and the ElCo has something different, then you're into a different crossmember, possibly different driveshaft, etc.
Old 05-27-2008, 07:57 PM
Th400 requires a shortened drive shaft and a different cross memeber. But unless its a 70 (Maby 71 too) your stuck with a TH350 which is a great transmission stock if your not pushing much more than ~350lb-ft
Most likely a TH350 in the Z (2nd Gen 70-81). Unless its a 3rd gen then the 700r4's were used. (82-93, arround '93 brain fart.)
305 TPI swap to a '76 350, can it be done? 70bird Engine 12 12-22-2004 12:39 AM
Tpi 305 To 350 Teejay68 Engine 3 11-26-2004 12:43 PM
will 4bbl carb from a 350 fit a 305 chvy engine slim3058 Engine 4 10-19-2004 03:52 PM
305 convo to 350 pillsbery Hotrodding Basics 7 06-29-2004 07:02 PM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 08:19 PM
