will a 350 fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2004, 08:24 PM
New Member
will a 350 fit?
as you know i know nothing about mechanics as of yet, but i have an opportunity to get a chevy 4 bolt main with a cast number on the block of
c
01
20
will it fit in a 65 pontiac lemans, will i have to do alot to make it fit?
any help will be greatly appriciated.
Old 03-01-2004, 08:30 PM
Sure, it will fit easily. You might have to change the engine mounts, but there is plenty of room for it. I am running one in a 1966 LeMans I just bought.
Old 03-01-2004, 08:32 PM
New Member
thanks
hey cheezebay, i appriciate it very much, will it hook right up to a powerglide tranny?
Old 03-01-2004, 08:53 PM
As far as I know it should. I have been thinking about using one on mine. I have a 350 turbo, but I have problems with mounting my starter on the motor and have been told that with some powerglides I can mount the started on the bell housing.
Old 03-01-2004, 09:28 PM
BOBCRMAN@aol.com's Avatar
If you are trying to use the two speed trans that came in the Lemans you may have a bellhousing problem. The Pontiac two speed has a different bolt pattern than the Chevy, but adapters are available. Just use V-8 Chevelle frame and motor mounts.
Old 03-02-2004, 03:25 AM
stepside454's Avatar
stay Pontiac power. I love SB Chevys, but Chevy crossbreeds are no fun, uninteresting. just my 2 cents. John
Old 03-02-2004, 04:43 AM
mikeweyman's Avatar
Last journal entry: 2 years later
find a pontiac 350, it will bolt right up
Old 03-02-2004, 06:39 AM
poncho62's Avatar
Wiki Edits: 5
Whats in the Lemans now, 6 or V8?
If going with the Chevy motor, get a turbo350, they are a dime a dozen.....well, not quite, but cheap. You will be much happier.
Ontario Rodders
Old 03-02-2004, 11:56 AM
New Member
currently has V-8
my lemans currently has a 389 in it, it runs great, but i dont want to take the 389 and get all kinds of honing and goring done to it, trying to keep engine pretty original.
Old 03-02-2004, 03:22 PM
if your consirned about keeping things pretty original, get another Pontiac motor. I realize there not as cheap as chevys, but by the time you buy a differant tranny, brackets ,starter etc, etc etc, you may as well stay Pontiac. Also, starters are on oppisite side, so youll have to butcher some of the wiring to go with a Chevy engine.
When finished, itll be much cooler with a Pontiac than a Chevy engine , in my opinion anyway, but than, its your car. John
Old 03-02-2004, 03:53 PM
New Member
i agree
your right john, i agree with you, i do wanna stay with the pontiac power, and yes it will probably wind up costing the same in the long run, thanks
Old 03-02-2004, 10:23 PM
poncho62's Avatar
Wiki Edits: 5
Like you said, the 389 runs great, so why change anything?
Ontario Rodders
Old 03-03-2004, 02:53 PM
Tazz
chevy or Poncho power??
Whats wrong with running the 389? Does it smoke or drip oil all over? Please explain your thinking.
Tazz
Rat Rods Rule!
Old 03-09-2004, 02:46 PM
bullheimer's Avatar
NEVER use credit cards!
i agree. build the poncho. use that SBC for a boat anchor. hahahahahahaha. oh yeah. i have one too! but at least its in my chevy.
