Will a 4.00 inch stroke fit in a stock 400 chevy block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2005, 09:44 PM
I was looking through the rotating assemblies in Summits catalog and saw a 4.125 inch bore and 4.00 inch stroke kit making a 427 small block. My question is can you clearence a 400 for the 4.00 inch stroke or do you need to use the World block for it?
Old 08-19-2005, 09:50 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I have wondered the same thing myself.
Old 08-19-2005, 09:59 PM
Bumpstick's Avatar
Hammer and a torch
I think you can but you must use a small base circle cam... I think the original 434`s were done by using a factory GM block but also with an aftermarket block a SBC 454 or even have heard of a 500cui SBC but very exotic...
Old 08-20-2005, 12:58 AM
You can do it and we have quite a few times. A later model 509 block with a short fill and lots of grinding on the Bridgeport. Splayed main caps as well. We have never used a Summit kit to do this though. We will use either a good Scat crank, Lunati or Callies.
Of course the block is poked, prodded, magged, sonic checked, pressure tested prior to all this cubic dollar outlay.
I'd frown on doing it if you can swing for an aftermarket block. It's a hundred times better as a foundation and in the end not that much more money.
Old 08-20-2005, 08:12 AM
The kit was in Summit but it was made by World. Summits kits dont offer a 4.00 inch stroke for a small block that I an find.
Old 08-20-2005, 10:04 AM
347mustang's Avatar
he was talking bout a 4.00 crank in a small blcok 400...yes it will fit..but you have to use strocker parts..like clearanced rod bolts-rods...and must use a small base circle cam...notch the block..to get the 427-434 ci...
Chevy block interchangeable with Pontiac / Olds/ Buick JACK Engine 10 04-20-2011 08:16 PM
i'm looking for a better 400 s chevy block 406 ss monte Engine 3 08-23-2005 08:48 PM
Pics of stock Chevy 350 short block Eazy (Jax, FL) Engine 2 07-05-2004 09:02 PM
Ford 400 Press Fit Hose Outlet ???? gohealthyhome Engine 4 07-09-2002 06:31 AM
big block chevy fit in 1954 truck pkaszuba Engine 3 01-03-2002 08:08 AM
