will a 40 chevy truck fit on a S-10 frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2008, 05:35 PM
71corvette's Avatar
I know later years will but it looks like the 40 may be more narrow. has anyone done this? or possibly another donor?
Old 11-27-2008, 06:26 PM
302 Z28's Avatar
I have a friend who put a 48 Chevy truck on an extended cab S10 frame.
Vince
Old 11-27-2008, 06:38 PM
71corvette's Avatar
Vince
yes that swap is easy, they even make kits for it. I need to know for a 40. thanks
Old 11-27-2008, 08:54 PM
Countilaw's Avatar
Cox Custom Cars
The 40 and 41 thru 46 Chevy trucks have the same cab and bed. There a few differences in the front fenders and grille. The answer to your question is Yes the 40 will fit on a late model S-10.
There are a few adaptations that will have to be made though. The cab and bed will not fit directly on the S-10 frame, But a Company E-Z Swap Chassis
E-Z Swap Chassis
has a kit that adapts the S-10 long bed frame to the cab and bed. It also adapts the radiator support. The kit also allows you to use the S-10 steering column, brake and gas pedals to the cab. The kit also supplies steel plate to replace the firewall predrilled for the S-10 booster and master cylinder, battery bracket and engine mounts. All these adapters fit the needed parts from the S-10 to the 41-46 which also fits the 39 and 40 1/2 ton pickups.
Frank
ID:	34455   Click image for larger version
ID:	34456   Click image for larger version
ID:	34457   Click image for larger version
Old 11-27-2008, 09:14 PM
Countilaw's Avatar
Cox Custom Cars
Here some of the latest pics of the mockup stage of my 46 1/2 ton, that started out as a 3/4 ton flat bed. This is using the E-Z Swap Chassis kit.
The major drawback of the S-10 swap is that the wheel width is 2 inches too narrow. You will have to use a 2" spacer that you can get from:
Billet wheel spacers
These are the best spacers on the market for this kind of application.
If you want to put disk brakes on the rear it's best to use a late model Tahoe rear end.
Frank
ID:	34459   Click image for larger version
ID:	34460   Click image for larger version
ID:	34461   Click image for larger version
ID:	34462   Click image for larger version
Old 11-27-2008, 09:43 PM
71corvette's Avatar
thanks that is some very useful info. is it the front that needs the wheel spacers? is the tahoe rear close to the correct width? looks like you truck is coming along nicely. I am in the middle of street roding a 50 model chevy truck, build thread here
http://67-72chevytrucks.com/vboard/s...d.php?t=296770
and my friend just bought this 40 pickup. he wants me to help him with it. any advice on a certain year S-10, I think I read the 4x4 models had rear disc brakes. does this lower the truck like it does on the AD models?
thanks again
Old 11-27-2008, 09:54 PM
Countilaw's Avatar
Cox Custom Cars
The 4x4 rear end will work nicely. Then you will only need the spacers in the front.
Frank
Old 11-27-2008, 10:09 PM
71corvette's Avatar
Frank
did it lower your truck?
Old 11-28-2008, 12:58 PM
Countilaw's Avatar
Cox Custom Cars
I've lowered the front by 2". The truck is sitting level right now. After I get the final wheels and tires on, I will decide if it needs more.
Old 11-28-2008, 07:44 PM
71corvette's Avatar
good, I was hoping it would
Old 12-07-2008, 04:56 PM
71corvette's Avatar
countilaw, Mar K list beds for 41 on and not for a 40 model. is there any difference in the beds? running boards and rear fenders are the same for 40-46
Old 12-07-2008, 07:39 PM
Countilaw's Avatar
Cox Custom Cars
Yes it will. So will the 47 through 52 beds.
56 chevy truck frame swap kid Suspension - Brakes - Steering 3 08-06-2006 05:45 PM
440 fit in 55 chevy truck? JFK Engine 2 07-28-2005 10:03 AM
Mustang II in a '40 Chevy sedan noxqsz Suspension - Brakes - Steering 4 06-28-2005 12:35 AM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
chevy 10 mbolt to fit my 37 ford coupe deddy Transmission - Rearend 2 05-27-2003 04:35 PM
