Will a 4L65E be fine behind a ~460hp LT1? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2010, 09:23 AM
something droll and pithy
Vehicle: 1964 F100 shortbed
Engine: 1998 383 LT1 - ~460hp/460tq as shown here
Rear: Ford 9 inch from a '72 Bronco (narrowest made)
Tires: Mickey Thompson Sportsman Radials (~31" tall and 15" wide)
Use: No towing or hauling, just daily (spirited) driving, cruising to shows a few hundred miles away, maybe one or two trips down the strip a year.
I've been reading about pros/cons of 65E and 80E, but cannot come to a conclusion. 80E has more parasitic loss, but is tougher, and I've read different things about 1st to 2nd ratios.
I'd like bulletproof over speed, so I'm leaning toward the 80E. I'm buying a new harness so connections aren't worrying me.
Recommendations? Any "gotchas?"
Also, suggestions on a rear ratio?
Thanks!
Old 08-05-2010, 11:12 AM
Update
Well, 63 have looked at my question, and zero responses, so this must be a tough one.
I've found places online like Goodfellas that say the 4L60E's can be built to withstand a lot of HP for a pretty reasonable price. It sounds good, but I'm still wondering if anybody can verify these claims.
Old 08-05-2010, 07:48 PM
Crosley's Avatar
Wiki Edits: 1659
you answered your own question about bulletproof .
Use the 4l80e
Get a custom built converter smaller diameter , I would not use the heavy OEM converter for the L80e trans.
LT1 Hotcam Install , Valve clatter Tuff96LT1 Engine 2 11-12-2008 12:53 PM
Lt1 heads on vortec block Ugly89Camaro Engine 3 01-14-2008 09:53 PM
Vortec heads on LT1 the dan Engine 14 12-29-2007 04:24 PM
LT1 headers...fit other heads? Speedyoldtruckdotcom Engine 2 06-25-2007 10:00 AM
Really fine scratches - How to remove dnwong Body - Exterior 1 11-16-2006 07:57 AM
