will 55 f100 spindles fit my '28 A axle?
please let me know. thanks.
Not really ... they have a different kingpin angle also. If you got them on ... the wheels would have way to much camber.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
oh. thanks!
what are some spindles i should keep an eye out to fit my 28 A axle? |
You must be wanting to use the 55 F-100 brakes and wheel pattern
So what I did was to buy a aftermarket axle and a set of 42 to 48 Ford car spindles. Works together perfectly. A stock 37 to 48 Ford axle will also work but be careful on the widths. The later ones are a good bit wider than your Model A axle. Go here for a online tutorial on installing the F-100 brakes http://www.flatheadv8.org/f1brakes1.htm Deuce ... Moderator
| Recent General Rodding Tech posts with photos |
| 440 fit in 55 chevy truck? | JFK | Engine | 2 | 07-28-2005 10:03 AM |
| Will ford 14" rallys fit granada spindles | FAIRLANE DUDE | Suspension - Brakes - Steering | 1 | 10-07-2003 09:23 PM |
| will these disc brake spindles fit my Torino? | jchris64 | Suspension - Brakes - Steering | 2 | 09-07-2003 05:20 AM |
| King-pin fit into chromed beam axle? | Limey Simon | Suspension - Brakes - Steering | 2 | 11-06-2002 04:40 PM |
| will this rear axle fit my AD / spring selection | solowookie | Transmission - Rearend | 1 | 03-06-2002 02:51 PM |
