Will a 69 Chevelle rearend fit my '67 Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2008, 09:35 PM
Last journal entry: more...
I bought a '69 Chevelle rearend for my '67 Chevelle. I was told it would fit but it was just like and inch wider. When I crawled under there today, I saw something a little different than the rearend I bought. The spring cups on the '69 axle have coils spring plates with a bolt to hold them down and my '67 has coil spring cups without a plate. Will this rearend still work without any mods? It looks to me like it will but I'd rather have a second opinion from someone a bit more experienced.
Old 04-26-2008, 09:57 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
I can vouch that a 67 Chevelle rear end is a direct bolt-in with swap with a 1968 Chevelle - I did that on my 68 to gain some additional tire clearance.
I don't recall having to weld or change anything on my swap - I can't imagine why the 69 would be different.
I take it the spring perch is in the correct place just a difference in the cup and hold down?
Old 04-26-2008, 10:10 PM
Thats right. Everything is the same place as far as I can tell except the cups and hold down. I'm pretty sure it will fit, I'm going to put install it tomorrow. I'll post again after I get done to whether it works or not.
67 chevelle malibu emblem placement bigfoot9090 Body - Exterior 4 04-07-2009 05:40 PM
'67 C-10 rearend Beef327 Transmission - Rearend 0 01-13-2005 02:18 PM
will 66 or 67 chevelle rear end fit dragrace87 Transmission - Rearend 1 07-21-2003 10:56 AM
will the rear end out of a '65 chevelle fit a '72 Snatch Transmission - Rearend 3 03-02-2003 05:15 PM
Do I have to shorten the rearend to fit bigger tires? fireschenie Transmission - Rearend 7 12-26-2002 12:45 PM
