Will 70's Nova Work ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2003, 04:20 PM
Question Will 70's Nova Work ?
Still looking for match for 49 chev fleetline rearend. Thanks Deuce but would like somthing newer if possible.
Old 02-23-2003, 04:47 PM
Nailheadforty's Avatar
Nailheadforty
Talking
I think your headed in the right direction. Check out the "Knowledge Base" there are some good articles regarding your question in there. You have two dimensions that you should be concerened with. That is the the distance between the spring pads, and the "flange to flange" distance. If you can do your own welding, so that you may relocated the pads, then you need be concerned with only the Flange to Flange distance. The early 68,69 Camaro should be a close fit also. Let me know if I can be of help, Good Luck. <img src="graemlins/boxing.gif" border="0" alt="[boxing]" />
Old 02-23-2003, 04:58 PM
BOBCRMAN@aol.com's Avatar
Post
how about 2-wd s-10 or astro van?, i have used them quite a bit, fit my 36 Terraplane, have used then in early pickups, and a 50's studie.
Old 02-23-2003, 07:30 PM
slider in wa's Avatar
Slider in Wa.
Post
I do not know the differance between your year truck and my 57 Chev when it come to width. However i installed a 83 Camero rear end under my 57. and it fit perfict. Had to move the spring perches.
Slider in Wa.
Old 02-25-2003, 08:19 AM
Post
The 68-74 Nova rearend fits well under virtually every Chevy car built before 1958. The spring pads must be relocated/replaced but that's pretty much the hardest part of the swap. When you get the rear-end take the driveshaft as well; on some swaps it will bolt right in with no modifications. TRY IT! YOU'LL LIKE IT!
