Will they fit my 1969 Camaro with drums? I can score them for an even $75 bucks.
ELi |
bolt in, Your in luck.Dont forget to swap the master cyl.also. Good luck. JF
'67-'69 Camaro & Firebird, '68-'74 Nova & clones, & '67-'72 Chevelle & clones are what to look for. Chevelle calipers may not be the same, but the spindles & rotors are.
'69-up have the single-piston calipers, and parts for those are much easier to find than for the earlier years' 4-piston units. Your steering arms will work fine, but if you find a donor car with shorter ones, they'll give you quicker steering. Do not use Chevelle steering arms, they will screw up your steering geometry. |
The other thing that most people seem to overlook is that the two piece spindles (67-69 F-body, 64-72 A-body, and 68-74 X-body) have a different ball joint stud taper than the later spindles. Yes you can physically bolt them up, but it's unsafe. The ball joint studs will be overloaded and can break.
Those different-length arms I referred to were used only on the cars with the rear-steer versions of that suspension design, and differ only by length of lever arm, as far as I know. The ones I've seen seem to have a similar angle off the mounting plane, so I don't think it would mess up the Ackerman. Bump steer I don't know so much about, but in my limited experience, I've never noticed any instability or other untoward effects after converting from the long arms to the short ones. Both of my Novas were set up to not lean too much when cornering, so maybe it wasn't enough of a difference for me to notice. |
