will a 74, 194 six, work in a 47 ford car??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2007, 10:06 PM
trying to replace the 100hp flatty. looks like the three sp. will hookup to the collum shifter.
Old 05-08-2007, 11:19 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
What are you planning to use for a rear end?
Old 05-09-2007, 12:18 AM
strummin67's Avatar
Violating consensual reality
Last journal entry: Taking a short break
Now that is different. Refreshingly different!
Old 05-09-2007, 04:13 PM
Wiki Edits: 31
very well could hook up, tho the hood on a ' 47 ford is pretty tall. I'd run a 292 6, if you could find 1, or maby a 270 or 302 GMC.
Old 05-09-2007, 05:03 PM
strummin67's Avatar
I'm guessing you have the 194 already. They're not bad engines. I have one in my Nova and it's going to be working very hard to move your Ford around. I'd go with a 250 or the taller deck 292. The rear mounting bolt pattern is identical to the small bock Chevy and if you decide to swap in a T5 5 speed or a GM automatic they'll bolt up with very little modification.
Old 05-09-2007, 05:10 PM
home brew's Avatar
Why would you go to the trouble of swapping a 100 hp Ford flathead for a 120 hp Chevy? The column shift linkage may hook up but how are you going to hook up that torque tube rear end with that new tranny?
Old 05-09-2007, 06:55 PM
Wiki Edits: 31
wouldn't have to, there are adaptors to fit SBC's to old Ford transmissions, speedway sells them, the tranny would take the pounding too.
Old 05-09-2007, 07:17 PM
jalopy45's Avatar
Gotta love it....Dare to be Different., look at the www.inliners.org web site for making that 6 work for you
Old 05-09-2007, 09:37 PM
home brew's Avatar
I disagree. I broke every three speed tranny I had in my 40 ford tudor. At first I had a slightly warmed over flathead in it and then a 324 Olds. First gear always went out. Swapped a lot of cluster gears into that 39 box in those days - but at $5.00 to $10.00 a tranny it didn't hurt my back pocket to bad (of coarse I was making a whopping 92 cents an hour then).
Old 05-09-2007, 09:55 PM
junior stocker's Avatar
It says "74 194" ; in 74' it would have to be a 250 or possibly a truck 292; last 194 was in 67'. The 194-292 Chevrolet I-6 have the "V-8" bellhousing mount and will take the same flywheels,clutches, and starters. The original 194 stickshift flywheel/clutch is tiny and needs to be replaced with something bigger anyway; seems the flywheel was recessed for the clutch if I remember right.
47 FORD "TITLE" ONEGALONLY Hotrodders' Lounge 8 03-10-2006 05:15 PM
47 ford rear swap (parallel leaf springs) ONEGALONLY Suspension - Brakes - Steering 4 10-06-2005 07:06 AM
I am never going to let anybody else work on my car. onebadmerc Hotrodders' Lounge 19 12-22-2004 07:52 PM
i need to start the body work on my car montea Body - Exterior 11 11-01-2004 12:39 PM
Picking a color Wmarden Body - Exterior 6 10-23-2004 11:13 PM
