Will 75 nova spindle work on a 71 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 05:10 PM
I got some 1975 nova spindles with brakes set up will these work on a 1971 nova would like to switch my drum brakes to disk i know now that the upper control arms won't work lol live and learn!
Old 02-01-2009, 05:45 PM
The 68-74 Nova is rear-steer (steering linkage behind the wheel centerline. The 75-79 Nova is front-steer. No, you can't just swap the spindles side-for-side. Compounding this problem the 75-79 cars use ball joints with different stud taper. It is not safe to put the later spindles on the early ball joints.
Old 02-01-2009, 06:04 PM
thank you
Thank you very much this novice is thankful for your knowledge!!!
71 GMC Sprint SP400, 69 Yenko Nova 71SP400 Introduce Yourself 2 08-13-2008 08:16 PM
Going From Small Block To Big Block In '71 Nova... STATUTORY GRAPE Engine 4 07-13-2008 03:14 PM
Will "modern" speakers work on my '71 Cadillac? FlipperFish Electrical 3 03-20-2005 05:22 PM
Monojet Carb on a 71 all original Nova? ToYoungToCare Engine 3 06-20-2003 05:11 AM
Will 70's Nova Work ? bryyrb Transmission - Rearend 4 02-25-2003 08:19 AM
