will a 80's starter work in a 70's chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 02:45 PM
will a 80's starter work in a 70's chevelle. i was changing my starter to a smaller 80s starter found there was no r post for coil. where do i connect coil ( r wire ) to?
please help. thx R5
Old 06-25-2012, 04:54 PM
EOD Guy's Avatar
If you are running a coil/points type system you're going to to have to do one of two things...... get a starter solenoid with the "I" (goes to the coil), "S" (goes to the ing switch) terminals or switch over to an HEI type ing system. HEI doesn't require the "I" terminal. You could rig up a relay to simulate this.... but why.
When the ing key is turned to start, The "S" terminal recieves power from the ing switch and engages the solenoid which then sends a full 12 volts out of the "I" terminal to the coil to aid in starting, after it starts and the ing switch returns to the run position, the "I" terminal goes dead and the coil recieves 9ish volts via a resistance wire or ballast resistor which prolongs the life of the coil. The coil would burn up in short order if it recieved a full 12 volts all the time.
Old 06-26-2012, 03:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
please help. thx R5
You can also set it up w/a Ford type solenoid. More here.
chevelle body work Chevelle427Rat Body - Exterior 7 03-10-2011 09:47 PM
Will This Starter Work? HotRodMan Engine 2 08-27-2006 09:45 PM
where's my starter?? 69 chevelle malibu 307 malibuman Engine 6 10-30-2003 10:50 PM
bad starter? 69 chevelle malibu malibuman Engine 1 10-25-2003 11:55 PM
Chevelle starter wiring Tom S Electrical 2 08-04-2003 08:41 PM
