Will A 82 700r4 Fit Into My 85 C-10 Without Problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2005, 07:37 PM
I have a 85 with a 700r4 and found one on a 82 c-10, I have never done anything like this before but am ready to get my hands dirty if it will work. My trany is starting to slip and would appreciate any response.
thanks in advance
Frank
Old 06-04-2005, 10:29 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
get one from like 90 & up the older ones are suppose to be JUNK (even though i got 250,000 out of mine, 84 burb). all the builders say to use the newer ones since they are built better..but yes it will fit & the electric stuff should be the same...joe
Old 06-05-2005, 05:47 PM
My 85 C-10 trany swap
Does it make a difference if they recently rebuilt it? I was told I need a new torque converter because the one I have in my 85 will not fit in the rebuilt 82 trany and If I went with a newer one I need electrical or computer components, but Im not sure if im saying that correctly.
Sorry for the late response, I went to the goodguys auto show in Pleasanton ca today and just got back.
Thanks, I appreciate all the help I can get.
Old 06-05-2005, 06:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF you are simply driving the vehicle as a daily driver... the 1982 unit will function fine.
The 1982 units had a smaller input shaft, the torque converter must match the shaft.
If the 1982 unit was rebuilt correctly , then it should work fine
Old 06-05-2005, 06:35 PM
It is a daily driver and the trany im buying for $300 and wants to sell me a tci breakaway torque converter that will only fit 81-84 th-700r4 for $250 and I did not know I needed to spend that mutch more. I thought my torque converter would fit but im not sure. Im new to all of this and thanks again.
85' 700r4 info GoneNova/406 Transmission - Rearend 4 08-06-2004 12:56 AM
Rebuilt 700r4 Burnt in 10 miles subman17 Transmission - Rearend 9 02-15-2004 03:41 PM
would '93 lights fit an '82 mustang? 2506CYL Body - Exterior 1 12-24-2003 07:18 AM
GM 8.5", 7.5" 10 bolt ?? and 700R4 ?? williemon Transmission - Rearend 4 12-16-2003 03:11 PM
chevy 10 mbolt to fit my 37 ford coupe deddy Transmission - Rearend 2 05-27-2003 04:35 PM
