Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - will 91-96 caprice suspension parts and rearends fit in my 85 caprice?
Old 10-14-2010, 02:26 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by joe_padavano
Considering that the frames and suspension are the same, that seems like a lot of work for zero gain. The spindles and rear axles are the only differences.
True, unless the 91-96 frame is from the 9c1 police package, then it has stiffer springs, bigger anti-roll bars, higher durometer bushings, bigger front brakes. If I had the cop car, I'd probably do the complete frame swap,. If not, just a rear swap and then rebuild the suspension with poly bushings and add aftermarket anti-roll bars.
