Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - will 91-96 caprice suspension parts and rearends fit in my 85 caprice?
Old 01-17-2012, 03:59 AM
topmeat69 topmeat69 is offline
Originally Posted by ironindian77
I wondering if 91-96 caprice suspension parts and rearend will fit in my 85.because I'd like to put a 300 hp 350 in my 85 and I know the 7.5 won't last to long.I thought I read some were that the 91-96 caprice 8.5 rearends were a straight bolt in just they were a little wider.I was also wondering if the front and rear suspension parts would also fit.I'm trying to make a 85 caprice ss of sorts.
You can get the spindles off of the caprice wagon,it used the larger front disc,but the wagon had a 5 in bolt pattern, so you order the front disc for the LE1 racing camaro and it has the 4 3/4 in. bolt pattern they cost the same as regular disc, I did all of this to my 85 caprice 2 door,it made for a very cost effective improvement in braking
