will 91-96 caprice suspension parts and rearends fit in my 85 caprice?
13K views 20 replies 8 participants last post by  RunswScissors
I wondering if 91-96 caprice suspension parts and rearend will fit in my 85.because I'd like to put a 300 hp 350 in my 85 and I know the 7.5 won't last to long.I thought I read some were that the 91-96 caprice 8.5 rearends were a straight bolt in just they were a little wider.I was also wondering if the front and rear suspension parts would also fit.I'm trying to make a 85 caprice ss of sorts.
#2 ·
Yes, the parts bolt in, but the later axles will have the 5 x 5" bolt circle, whereas yours are 5 x 4.75" unless your car is a station wagon or has HD brakes (police/taxi package). Also, wagon rear axles are several inches wider than sedan axles.
ericnova72 said:
The whole '91-96 frame complete with rear axle and front suspension can be swapped to your '85, there is a member here with a thread about his '77 Impala, he is swapping in the '91-96 frame.
Considering that the frames and suspension are the same, that seems like a lot of work for zero gain. The spindles and rear axles are the only differences.
#6 ·
True, unless the 91-96 frame is from the 9c1 police package, then it has stiffer springs, bigger anti-roll bars, higher durometer bushings, bigger front brakes. If I had the cop car, I'd probably do the complete frame swap,. If not, just a rear swap and then rebuild the suspension with poly bushings and add aftermarket anti-roll bars.
And again, all of those pieces bolt into the 1977-1990 frame. I would much rather swap springs and sway bars than a whole frame, but hey, that's me. You only need to spin one cage nut on the body mounting bolts...
#8 ·
Consider the Caprice Wagon springs on the sedan
I installed wagon springs on 3 sedans,83,85,91 and soon a 96.I feel the wagon springs are stiffer than what GM put on ANY sedan including the 9C1.The improved handling was GREAT,the cost is about $80. for 4 coil springs.And it makes for a much safer car.
#9 ·
You can get the spindles off of the caprice wagon,it used the larger front disc,but the wagon had a 5 in bolt pattern, so you order the front disc for the LE1 racing camaro and it has the 4 3/4 in. bolt pattern they cost the same as regular disc, I did all of this to my 85 caprice 2 door,it made for a very cost effective improvement in braking
#10 ·
My first car was a '78 Aerocoupe Caprice. I still have it. As mentioned, all the suspension parts from 77-96 interchange.
One thing you might find interesting is that some of the Buicks had an extra bar on the rear of the frame that gave it extra stability (maybe the station wagons too??).
Here's my car in front of our family dealership, before the Government tore it down in 2009. The federal government closed us up and coincidentally the local government (which had a council full of corrupt idiots, literally) planned to tear the building down and put a building there. The building had been there since the 20s.
#12 ·
I'm looking at buying a '94-'96 Roadmaster for a donor car. I plan on using the engine, trans, steer column, modified seats, and electrical. I'll would also try to use the front steer components to do a front suspension upgrade similar to http://www.crankshaftcoalition.com/wiki/1937-1957_Buick_Oldsmobile_Pontiac_suspension_upgrade. Not sure how well the parts will work yet because the lower arms are not symetric like my old Buick.
1) Assuming I can use the suspension, is there any advantage to buying a sedan or a wagon as a donor car?
Thanks
#16 · (Edited)
Thanks
If you ever want to do discs, 9c1/Impala SS rear brakes fit the sedan axles without mods. You can get the discs to fit the wagon, but it's just another step you'll need to take. I don't really see an advantage of a wagon axle over the sedan, they are largely the same aside from the LCA mounting further outboard on the axle, and the frame is wider in the back. I guess it depends on what car you are putting it under, and if you can see an advantage of the different track width and slightly different suspension.
I have done 3 B-car frame swaps, the most recent about 3 weeks ago. I put a 94 9c1 frame under my 79 Coupe. Reading the comments above, I did it because the new frame was a southern frame from AZ, was already repainted, and had a completely rebuilt front and rear suspension. Much nicer than the crusty frame I had under the car. It's not a ton of work, we did the swap in 8 hours, and I'll never have to touch the frame again.
You can do it with a hoist, or with some forethought, some stands made out of 2x6's and a Cherry picker.. did that twice...
Regarding 8.5" sedan axles, I redrilled the axles on one of my bare 9c1 units. The backing plates from an earlier car will fit, but the hub locator flange on the 91-96 axles is larger, so my stock 9" drums would not fit. You can get a 91-96 with 9" drums, so I did that and drilled the pattern to 5x4.75". You can do this on a drill press. I transfer punched the pattern from my redrilled axle shafts (which were done on a mill with very good accuracy), and drilled the holes to 1/2" The drum located on the center flange, and gets clamped to the axle by the wheel, so getting the bolt pattern perfect is not very critical.
FWIW, you need to be careful with which axle you use from 91-96, there are 7.5" axles on a lot of those cars, 94-96 is a safer bet, but even then some 4.3L V8 cars were 7.5. There are also 2-3 different widths. Log on to impalassforum.com, there are stickes in the driveline section that detail the widths.
Regarding springs, it's a mixed bag. The junkyard is your friend. The rates are not often that different, but the free height is, so it changes your ride height among sedans. On wagons, they definitely had stiffer rear springs AND a taller free height.
#19 ·
taller free height springs ?
when you say "On wagons, they definitely had stiffer rear springs AND a taller free height. " what do you mean? I installed wagon springs on 5 caprices and when the speings were out of the car sedan springs setting next to wagon springs, the sedans spring were much taller and the wagon springs weighted one pound more than the sedan springs.. thanks
