Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will '95 Roadmaster parts mate to Scout 2 steer box?
Old 01-21-2013, 07:34 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
Thanks for your help. The 1973-1987 GM full size pickups steer box will not work for me becasue plan on keeping rear steer due to the geometry of the frame.
I'm converting my 37 Roadmaster ifs to ball joints and disk brakes similar to the wiki:
http://www.crankshaftcoalition.com/w...ension_upgrade
The difference is that I'm using the spindles and brakes from a donor car which is a '95 Roadmaster. The spindles will be swapped left to right to maintain the '37 rear steer. The ackerman angle aligns well with this swap.
This change means I need to handle power steering differently than the second part of the instructions found at:
http://www.crankshaftcoalition.com/w...inion_steering
The steer arms on the 95 Roadmaster spindles are too long to allow rack & pinion unless I go with a very expensive after market r&p.
I plan on use a center link with a steer box mounted on the outside of the frame because the frame is very narrow at the front axle.
The idler arm length willl match to the pitman arm length.
Thanks
