Will a 96 4L60-E, 4x4 transmission fit in a 98 z71? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2011, 01:03 PM
dalamb13's Avatar
Have a 98 z71 and the transmission is messed up...Will a 96 4L60-E, 4x4 transmission work?
Old 12-31-2011, 07:53 PM
tnsmith10's Avatar
when will it rain???
the trans will bolt up to the block as the bolt pattern is almost identical but, it will not work.you need the proper year case for the 98. the difference is in the front of the trans at the bell housing (98-up is a bolt up bell housing), and the converter.
Old 01-01-2012, 11:31 AM
pricesgarages's Avatar
the 98 wouldnt work porperly either the fisrt few yrs they changes solenoid restances 97 up to 05 will work with out a problem i think the ck trucks still had a 1 pices case in 98 but ive seen 5.7 and 5.o with the removable bell housing u need a 96 unit or you origional unit rebuilt
93-94 will only work in those yrs
95 will only work in a 95
96 will only work in a 96
97 up 5.0 and 5.7 will work in a 97 up
4.8 and 5.3 will not work on a 5.0 or 5.7
Old 01-01-2012, 09:15 PM
dalamb13's Avatar
Okay thankyou. Unfortunately The transmission has already been bought.
Old 01-02-2012, 05:43 PM
if u know the 96 is good swap the internals clutches band drums use your valve body and pump that may save u a few dollars
Old 01-02-2012, 07:55 PM
dalamb13's Avatar
okay. Thankyou very much!
4L60 Transmission won't shift ddjd Transmission - Rearend 9 05-12-2011 08:40 PM
Need to swap out a 4L60 in 1988 GMC with a 1992 4L60 limp'n-gmc Transmission - Rearend 6 03-10-2011 05:17 PM
4L60-E transmission acting weird yzas Transmission - Rearend 1 10-14-2010 06:42 PM
4l60 E transmission probelms c65shoebox Transmission - Rearend 6 02-05-2009 05:04 AM
thm 700 r4 4l60 lawyernie Introduce Yourself 2 12-07-2004 04:36 PM
