will any wrist pin fit any piston? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 10:35 PM
jesse01's Avatar
mini me
hey everybody.
I bought a set of pistons for my 383 I'm re-building for my caprice, but they come either w/pressed or bushed wrist pins for the rods that come with them, and I don't really want either or. I want full floating pins
so can i take those rods out and put rods fitted for a full floating wrist pin in these new keth black pistons i bought?
do any of you guys know or have done something like this before?
or am i waisting my time? should I just use the ones i have now? or should i just get a new set of pistons that already have a full floating wrist pin rod?
help me i'm clueless when it comes to rods & wrist pins
thanx
jesse
Old 03-23-2005, 10:45 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Bushed rods are for full floating wrist pins. full floating pistons have clips (like a c-clip) that holds the pin in place.
Old 03-24-2005, 07:45 AM
BOBCRMAN@aol.com's Avatar
As stated, your pistons will take either style rod, Pressed style rod does not use the pin retainer clips. Floating, has a pin that slips thru the "eye" of the rod and have circlips in the piston pin bore, to retain position of the pin.
The dimensional difference is in the rod end, not the pin. The pins are fitted to the piston at a very close tolerance. Do not mix the pins, or try to modify them. Unless you know what you are doing! You can get some mighty strange knocks/sounds/damage from improperly done wrist pins..
Old 03-24-2005, 08:46 AM
MI2600's Avatar
Member# 3287
The question in the back of my mind is if you don't know the difference, why do you HAVE to have floating pins?
Old 03-24-2005, 08:52 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I wondered the same.
Sounds good I guess.
Old 03-24-2005, 03:44 PM
jesse01's Avatar
mini me
I was told that "full floating pins" were better & that they let more oil circulate through the piston
if i'm going to put my 383 back together w/ more hp i want to have good parts & oil circulation, right?
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
