Will A blower cam work with nitrous. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2006, 10:55 PM
I was just wondering, will a blower cam work with nitrous? im building a blower motor but wont be able to get the blower till next summer. So i was just going to keep my 64cc heads on and run nitrous until i get the blower, then i'll switch the heads. Just wanted to know if the blower cam will hold up with nitrous, around a 75-150 shot.
Old 09-24-2006, 12:58 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi, I'm not clear on what your asking, but here goes. You can use a blower cam
you may just not get the results your looking for, a cam swap is no big deal,
why not put a cam in that will work the way you want for now, then put the
blower cam back in when you put the blower on.
good luck & keep safe,
Rich
Old 09-24-2006, 01:38 AM
In many cases a blower spec cam, wider LSA and additional exhaust duration is exactly what you'd spec for a nitrous grind. So yes, it will work just fine.
Old 09-24-2006, 01:59 PM
Thanks alot for your reply. So it will be ok to run a blower cam with just nitrous until i get the blower?
I've built engines before, but i've never messed with nitrous before.
Blower timing bailey40ford Engine 8 12-19-2011 05:58 PM
blower cam? RPMs Engine 5 06-16-2006 02:22 PM
will the cam work, hp prediction spyders03 Engine 6 02-22-2006 10:59 AM
head work or cam?? 69elcaminoss Engine 11 03-26-2004 10:30 PM
Work Van needs cam??? Intrepid8 Engine 2 06-03-2001 12:28 PM
