Hotrodders Bulletin Board > Tech Help> Body - Exterior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 11-07-2009, 12:43 AM
Ripped's Avatar
Ripped Ripped is offline
Last journal entry: First RoadCourse Video
Will body panel adhesive work for this?
I am thinking of using body panel adhesive for assembling various metal parts in a custom console that I am building.
One of the reasons, is that even if I tack weld from the back side, I may have (heat) discolouration which shows through on the finished side. I am making my console out of polished stainless steel, brushed aluminum, and of course som upholstery, plastic, vinyl etc.
What do you think?
Where can i learn about the application process?
How good is the adhesive and what is the usual tolerance?
The seams will all be hidden, so there is nothing visible from the topside of the console.
Thanks for any advise.
(some pics in the journal)
  #2
Old 11-07-2009, 12:48 AM
robweb robweb is offline
as long as you are bonding metal to metal with a good overlap( an inch perferably) I would say that would be a good way to go, what are you planing on bonding?
Old 11-07-2009, 07:02 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Old gunslinger
Wiki Edits: 11
Grind both mating surfaces first and make sure its where you want it because you'll never get it back apart.The metal tears before the bond will...I use SEM weld bond adheasive,just pick the set time you want..Sounds like an interesting project.
Old 11-07-2009, 07:48 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Ripped,
I've often thought of using adhesive to assemble some smaller, more intricate metal pieces but have always been perplexed with what to do with the raw edge of metal where you overlap the parts. Could you give some clues as to how you intend to deal with that?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 11-07-2009, 10:39 AM
MARTINSR MARTINSR is online now
Without a doubt your project is PERFECT for bonding.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Will body panel adhesive work for this?"
ThreadThread StarterForumRepliesLast Post
Confessions of an autobody shop owner. How to pick a shop to have your car restored.MARTINSRHotrodders' Lounge2701-29-2010 03:22 PM
Body work vs. painting partsdesadeBody - Exterior710-01-2007 03:20 PM
"a little over" turns into $4500 over for paint jobbullheimerBody - Exterior12802-06-2006 09:57 AM
Rookie on body work. Several questions.x-angelBody - Exterior1804-28-2005 12:32 AM
my doors got stretchednomad57ryBody - Exterior1712-02-2004 07:51 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
