will c-6 trans fit into a 302 ranger - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2011, 03:59 PM
I am building a 302 from a 1983 F-150 that had a C6 auto transmission. The engine is going into a 1985 ranger 4x2. Most posts recommend a c4 or c5 transmission, why not a c6.? Are there clearance issues or what is the reason?
Old 11-04-2011, 04:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would say it is the clearance issues they are talking about JMO
but IMHO the C4 would work best for what you are putting it in and you can build a C4 that can handle some pretty serious HP and alot more room to work with. JMO
Cole
Old 11-04-2011, 06:59 PM
Wiki Edits: 27
body lift
A 2 or 3 inch body lift kit would give you more room, the 302 has interference with the heater box, fuel pump and oil filter . A c 6 would most likely require floor pan hammering or cut and weld.
Pinto/ranger 5 speed manual trans questions CHEVILLAC Transmission - Rearend 1 05-24-2011 03:05 PM
v8 in a '90 ranger houndsplayer70 Engine 9 09-18-2007 09:48 PM
hey ranger v8 sheriffj Introduce Yourself 1 02-18-2007 07:04 AM
ranger with 302/351 k1500_3 Engine 7 02-02-2007 09:49 AM
1980 Ford Ranger XLT w/ 351M engine and C6 trans. wildfly Hotrodding Basics 9 01-03-2006 08:25 PM
