Will this cage pass tec.? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2012, 11:43 AM
TonkaYJ's Avatar
Last journal entry: Took her out for a drive Oh Ya! Gotta Love an LS powered early Vette
I hope to run low 10s with this Nova will this cage pass tec? Should I paint it before getting it inspected I think I need a seat back brace as well as seat belt tabs still, anything else that will need done or redone please comment, I want to race this car this season and need to get busy
Old 04-08-2012, 10:31 PM
Do you have a bar that connects the tops of the A-pillars above the windshield? Didn't see one in your pics.
Old 04-09-2012, 06:56 AM
TonkaYJ's Avatar
yes
Old 04-11-2012, 11:57 AM
68NovaSS's Avatar
Wiki Edits: 9
It looks almost identical to the Alston cage in my Nova except my rear braces are closer together to clear wheel tubs and attach to my back-half frame rails, and I have a swing-out side bar. NHRA rules, general regulations, 4.10 and 4.11, state the 6 x 6 x .125 plate must be welded or bolted x4 to the 'frame' in frame cars, and may be welded to the floor/rocker box on unibody cars, yours is welded to the floor and is a frame car, tech may call you on that. Also remember there are padding and helmet clearance requirements for thickness and placement and no grinding or smoothing of the welds is permitted.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 04-12-2012, 07:51 AM
TonkaYJ's Avatar
My car is a 68 Nova it has sub frame connectors and sub frames the main hoop and the a pillar are welded to plates welded to the rocker boxes the bars that go from the a pillar to the front of the car gothrough the fire wall and land on the front frame. The two rear most bars land on the rear sub frame with plates the only bars that do not land on plates are the to most foront bars and they land on the frame I have the plates welded to the rocker box not the floor also have a couple landing on the sub frame conectors
Old 04-24-2012, 09:54 AM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
Best Way, Trailer to the track and run it through tech inspection
MercedesMechanic/Tec Help CQNRQY Hotrodding Basics 4 01-06-2010 07:56 AM
EZ Pass {electronic toll pass} Rob Keller Hotrodders' Lounge 26 06-12-2009 06:07 AM
Looking for a GM Tec. 1981monte Engine 12 01-18-2006 05:31 PM
how much for t-tec flush?.... sc2dave Transmission - Rearend 2 04-30-2005 09:21 PM
E-Tec Head ? HotRod31 Engine 3 12-07-2002 06:11 PM
