Will this cam work for my stock vortec 062 springs?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-21-2010, 09:57 PM
CJ_1080's Avatar
known to do dumb stuff!!
Originally Posted by quicksilver67
I'll tell you from experience, you need to get the heads worked on. The Vortec heads will not accept a cam with more than 400 lift. After several broken springs and pushrods I found an article on Super Chevy that explained my problem. Heads must be worked on.
Sorry quicksilver, but you might want to read that Not-so-Super Chevy article again! Most vortec heads are good for .420-.460 lift! The Vortec's I had on my truck varried between .450-.465 stock. I ran the exact cam in my truck, with factory (very) tired valve springs for a year with no problems! Is it best to run factory springs on these heads in factory form? Probably not. Is it possible? Yes. You just have to check your retainer to seal clearance!
  #17 (permalink)
Old 12-21-2010, 10:39 PM
redfish211's Avatar
I really appreciate all the advise gentlemen... and I will post some snaps with I finish this engine.
  #18 (permalink)
Old 12-21-2010, 11:57 PM
CJ_1080's Avatar
Ooooh! Yea, maybe a healthy burnout picture!
  #19 (permalink)
Old 12-22-2010, 12:51 AM
spinn's Avatar
My 305 has vortec heads with 1.94 valves. Told that would not fit.
Vortec heads with unbrella seals and LS6 valve springs allow about .470" of lift. Currently my build uses the performer cam .420/.442 lift. No problems relating to valve lift. Drill pushrod holes to 3/8".
vortec roller cam stock push rod length aldfaa Engine 1 11-21-2010 07:13 PM
Help with Vortec Valve Springs set up camaro freak Engine 3 09-03-2007 09:53 PM
cam shaft and valve springs Arillious Engine 9 04-17-2007 03:52 PM
Vortec heads w/solid lift cam...anyone? rbomar Engine 6 08-25-2006 05:42 PM
Vortec Head Work MHenricks Engine 11 08-23-2002 12:06 PM
