will this cam work well? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2007, 10:57 AM
i have a 69 suburban with a 350 from an 88 1500 truck, a th350 tranny, stock converter(dont know stall). holley street doninator intake, holley 600cfm vacumn secondary carb, short headers.
the cam i am thinking of using is the crane version of the chevy 327/350hp cam. crn-967601. 222* duration in/ex. .447" lift in/ex. and i think 114* lobe seperation.
the truck is just a driver. do you think this will give me good midrange. would 1.6 or 1.7 rockers help or hurt?
thanks
Old 02-08-2007, 12:18 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Welcome to the site
Hope you enjoy your time with us.
Old 02-08-2007, 12:54 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by xntrik
Welcome to the site
HUH? Allright, who are you and what have you done with xntrik?
Old 02-08-2007, 07:18 PM
well, thanks for the welcome. i've already enjoyed looking around and just reading posts and articles in the knowledge base.
so, any ideas on the cam? how do think it will do?
Old 02-08-2007, 07:34 PM
xntrik's Avatar
If you pull 10* off the duration, you can pull 4* off the LSA, and make better low-mid torque,
but some people will disagree and want to make it a 5200 pound race truck.
I'd go for a 208* or a 212* on 110* LSA.
The camyou suggest will put your power peaks up at 4000 and 5600.
Old 02-08-2007, 10:06 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
Here's a very good, proven cam for applications just like yours. I have used this cam in dozens of engines and have never had a complaint. It is marketed under many brand names.
Specs are 204 @ .050 in. and 214 @ .050 ex.
.420 lift in. and .443 lift ex. with 112 of lobe sep.
It has a great idle and makes lots of torque.
Good luck with your project and welcome.
Barry
Old 02-09-2007, 08:48 AM
I agree 100%! The 350hp/327 cam is not for your application.
Get the performer cam (not performer plus or performer rpm) or get the summit cam of similar duration.
Yes, 204/214 degrees duration is what you need for a multitude of reasons. (low compression, poor flowing exhaust port, stock valve springs, stock rockers, small engine in a heavy truck)
Old 02-09-2007, 08:58 AM
xntrik's Avatar
There has been an influx of poor quality off shore lifters that are blamed for cam failures. Consider what you might be buying at bargain basement prices.
Old 02-09-2007, 10:01 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Agree with everything said above....... I know of 2 people that have used the Summit 1102 in large vehicles with high gears and relatively small displacement and it worked great.
One was a '63 Bel Air with a boneyard 305, 200-4R and 3.08's. It was no tire shredder but it could haul 4 adults no problem and got an easy 20 MPG doing it.
Just FTR, they had no problems with the Summit lifters but yes, there is some crap out there so do be careful.
Old 03-29-2009, 08:39 PM
thanks
1.6 rockers rv cams are rell good for suburban and trucks good midrange
Will this cam work with stock vortec valve springs? what is the accepted max lift? Warrant Engine 1 11-30-2006 01:56 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
The cam mistake is running, well, kinda! Jmark Engine 12 12-31-2003 12:49 AM
I think we made a cam mistake! Jmark Engine 11 12-30-2003 10:32 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
