Will a Camaro 5 speed connect to Chevy 292 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2012, 04:10 AM
Last journal entry: 1947 Studebaker Pickup M-5 Completed
Will a 86-89 Camaro 5 speed and bellhousing connect directly onto a Chevy 292?
or will it take a major modification.
Old 01-13-2012, 04:37 AM
SSedan64's Avatar
Doesn't the Camaro T5 mount on a left leaning angle? May make shifter location a problem.
T5 from 2.8L, 3.1L 3.4L V6 have 60* Bellhousing pattern.
62up Inline 6cyl. use the same 90* mounting pattern as SBC/BBC engines.
I'm not sure about Clutch parts. etc..
SBC = SmallBlockChevy
BBC = BigBlockChevy
Old 01-13-2012, 07:56 AM
RWENUTS's Avatar
Link for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
69 camaro automatic to 4 speed ? jaykooz Transmission - Rearend 1 01-11-2012 06:39 PM
1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. EricKessel Transmission - Rearend 1 08-08-2011 08:35 PM
94 camaro with v-6 5 speed 350 swap 350camaro67 Hotrodding Basics 3 05-29-2011 03:37 PM
Best 4 Speed in 67 Camaro 97laynlow Transmission - Rearend 6 01-12-2010 06:09 AM
T56 6 speed in a '79 Camaro bigblock454camaro Transmission - Rearend 1 11-21-2006 07:42 PM
