Will a Cloyes double roller fit behind stock cover? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 09:31 PM
I'm considering buying a cloyes double roller (CLO-C-3023X) for my chevy small block rebuild and I wondering if it fits behind the stock cover, or if I should consider their single roller (CLO-C-3001K)or a non-roller.
Old 09-13-2011, 09:43 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yes, IMO, it will.
I had to do a double-take on the subject line ... I must be getting tired?
I thought it said "stock convertor" at first, and was going to rib you about the timing chain goes on the opposite end of the engine.
Old 09-14-2011, 06:24 AM
Originally Posted by 66GMC
Yes, IMO, it will.
In your opinion it will?
Old 09-14-2011, 06:53 AM
engineczar's Avatar
Yes it will fit behind the cover. However you may need to clearance the block slightly above the center oil galley plug as it may hit depending on the accuracy of the block from the factory.
BSE Racing Engines
Old 09-14-2011, 02:40 PM
techinspector1's Avatar
Wiki Edits: 326
^^^ times 2
Old 09-15-2011, 08:50 PM
66GMC's Avatar
MY opinion obviously doesn't count.
Here's a better response:
http://www.cloyes.com/HighPerformanc...S/Default.aspx
Technical Help
Monday through Friday
8:00AM - 4:30PM Central Time
Phone:
(479) 646-1662 - Ext. 228
Fax:
(479) 646-5844
E-Mail: Click Here
Cloyes two pc timing chain cover? Bowtie man Hotrodding Basics 0 08-27-2011 09:04 PM
Gen VI Timing Cover/Double Roller Chain Kraneking Engine 6 03-01-2011 06:27 PM
Tell me why? Chevy CLOYES STREET True Roller Timing Set sp 9-1100SP monette999 Engine 8 10-09-2010 12:45 PM
Found problem with cloyes timing cover. eric32 Engine 3 07-23-2009 06:21 PM
CLOYES true roller chain set bullheimer Engine 3 06-07-2004 12:35 AM
