Will a clutch fan cool my 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2008, 11:01 AM
Im trying to get my car running as soon as possible. Im wondering if i run a clutch fan will that be enough for my motor?? Its a 400 sbc with aluminum heads.
Old 05-29-2008, 11:32 AM
Jmark's Avatar
That depends on a lot of things, but basic answer is yes.
Make sure the clutch is good, make sure you have the 7 blade fan and not the 5. A shroud is a MUST on any engine. Millions of small blocks out there running fine on a fan clutch.
Mark
Old 05-29-2008, 01:59 PM
327NUT's Avatar
+1, clutch fans work, some folks don't like the noise they make....a GOOD 180 thermostat, distilled water and not too much anti-freeze in the mix, make sure your timing is right and the alum. heads should help also. Hey Jmark...like your signature, no such thing as a fair fight!!
Clutch Fan malibuman66 Engine 18 01-01-2005 11:09 AM
Turbo 400 Clutch Flight Lostinspace Transmission - Rearend 1 07-11-2004 09:55 PM
Fan Clutch-or-no Fan Clutch, When An Why ALASKAN Engine 6 05-23-2004 10:55 AM
Best way to check a clutch fan? Jag Daddy Engine 1 05-11-2003 01:44 AM
Electric Fans VS Clutch Fan Jag Daddy Engine 18 04-25-2003 10:15 PM
