Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will epoxy primer fill 120 orbital scratches?
Old 04-25-2012, 05:13 AM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by jcclark
SPI epoxy, and most others will fill 120 grit scratches easily. Period!
I have filled 80 grit scratches with SPI epoxy many times
and never had a problem. (2 full strength wet coats)
The key is to have it cured enough before sanding that the
primer doesn't shrink after the sanding and the scratches show again.
I always let it cure 2 days out in the sun before sanding.
As long as you allow enough time after spraying for it
to cure before sanding you're fine.
The longer the better, everything shrinks, even epoxy.
thankyou sir!! sounds like a great plan!!
Andy
