will epoxy primer orange peel be visible after paint? - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
  #91 (permalink)
Old 06-09-2013, 10:49 AM
Originally Posted by Pats55 View Post
My name is Pat Mastrincola google me you will see how much i fear.Brain thank you for your kind remarks. It's deeply appreciated.
Holy crap what amazing life experiences you have had!
By contrast, I was delivering newspapers on my Stingray when you were walking the jungles of Naim.
  #92 (permalink)
Old 06-09-2013, 10:50 AM
life is a temporary assignment
I didn't read it all yet... But I will be the first to say thanks for giving your time to fight for us...
I was only two at that time..
  #93 (permalink)
Old 06-09-2013, 10:53 AM
Here here!
  #94 (permalink)
Old 06-09-2013, 11:01 AM
104 lbs !!!!! Sir you was a lean mean fighting machine...
  #95 (permalink)
Old 06-09-2013, 11:11 AM
Pats55's Avatar
thank you guys, I'm deeply touched, a couple more weeks they were carried me out of there.I was lucky guy compared to a lot of other guys. Wouldn't mind losing 20 pounds about now, maybe I'll go down to the Army /Navy and get some C rations
  #96 (permalink)
Old 06-09-2013, 11:37 AM
you guys are all like a bunch of ****ing teenage girls in the locker room. Jesus H. I guess now is about the time this thread will turn into the mandatory kumbayah circle jerk that so many threads here evolve into.
The Following User Says Thank You to Lizer For This Useful Post:
DLT (06-09-2013)
  #97 (permalink)
Old 06-09-2013, 11:56 AM
It happens because after a while we always realize how we are all human at some point! There is no face, we are looking at squiggly lines on a monitor, not a "person". Then after we get that image of a human being just like us, the hatred goes away.
  #98 (permalink)
Old 06-09-2013, 12:50 PM
First thing... I still stand my grounds for SPI products... That being said... I also know when to say thanks when I want too..
Now you can call it what you want..
  #99 (permalink)
Old 06-09-2013, 05:01 PM
deadbodyman's Avatar
Wiki Edits: 11
Great story. Let's not talk about SPI. Let's talk about self etching primer what happens when you scratch it. Will rust travel beyond scratch?
Heres the camaro I was talking about with the adhesion problem.I had scraped off some of the primer with a razor scraper leaving bare metal which had rusted,so to find out if the rust was bleeding through I scraped some more off the edge and there was a sharpe rust line showing me there was zero bleed through under the epoxy and this is WITH an adheasion problem from spraying when it was too cold out,my own fault...heres the pics.
ID:	74713   Click image for larger version
ID:	74714   Click image for larger version
ID:	74715   Click image for larger version
ID:	74716   Click image for larger version
  #100 (permalink)
Old 06-09-2013, 05:07 PM
Wiki Edits: 11
So then I noticed a spot under the plastic that was much worse since the plastic held the moisture there,I thought if there was a spot that the rust would bleed through under the epoxy this would be it but its the same zero bleedthrough as the other spots...Since this car had an adheasion problem to begin with I thought this last spot would surely have some rust under the primer but it did not...heres that spot with a few other pics...I was pretty impressed with the SPI before but NOW ,more than ever.
ID:	74720   Click image for larger version
ID:	74721   Click image for larger version
ID:	74722   Click image for larger version
ID:	74723   Click image for larger version
  #101 (permalink)
Old 06-09-2013, 05:11 PM
Pats55's Avatar
Thank you dead body man for answering my question
  #102 (permalink)
Old 06-09-2013, 05:35 PM
Wiki Edits: 11
Your welcome....Just so we're clear...we call acid primers etch primer and even though epoxy is a self etching primer we dont call it that, just epoxy.epoxy is also a 2k primer but we call urathane 2k not epoxy...so if you really want to start so sheet call SPI epoxy etch primer and watch allhell break loose.
  #103 (permalink)
Old 06-09-2013, 05:50 PM
Pats55's Avatar
again, thank you. The last steel car I painted I primed it with the Mastercoat silver, DuPont and Fill and Sand then a couple coats of red Centari. I'm not in the body shop supply business. As I said earlier, I had a little problem with epoxy quite sure was probably my fault. Having used any since There are so many combos zinc rich, zinc phosphate, acid etch . The guys on my staff their younger they are always painting cars and always correcting me I got one for you if I told you I could paint that Camaro with 1 quart of paint and cover it. would you believe me?
  #104 (permalink)
Old 06-09-2013, 06:09 PM
Wiki Edits: 11
Well....mabee you could but its going to take two gallons for me since the first gallon spilled on the floor....I do have a cool looking floor though that gives everyone a chuckle.
everyone but me thats a 350.00 spot on the floor
thats the second time I've done that in over 35 yrs and both times it was red paint ... also the only accident I've ever been in was in a red car ,Reds always been bad luck for me...
The Following User Says Thank You to deadbodyman For This Useful Post:
John long (06-09-2013)
  #105 (permalink)
Old 06-09-2013, 08:44 PM
LOLOLOLOLOLOLOL
orange peel in spi black epoxy primer cutthroatkid Body - Exterior 8 05-24-2013 06:50 AM
filler visible under epoxy primer ckliever Body - Exterior 8 07-10-2009 03:08 PM
Runs and Orange Peel on Epoxy Primer? Coodeville Body - Exterior 13 04-09-2009 10:09 AM
Spraying SPI Epoxy - Orange Peel starquest Body - Exterior 11 11-04-2005 07:32 PM
primer orange peel help jerrylo Body - Exterior 11 10-28-2004 05:52 PM
