Will a fel-pro steel shim work as a head gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2004, 08:07 AM
batman09's Avatar
CLICK ON MY AVATAR
Will a fel-pro steel shim(.015) work as a head gasket?Or is it as the name implies...a shim only?thanks bm
Old 12-27-2004, 09:14 AM
King of my Man-cave.
Fel Pro has a steel shim head gasket that is just that. They also have a copper head shim that is designed to be used with a head gasket to make up material shaved off of heads and blocks.
tom
Old 12-27-2004, 10:37 AM
willys36@aol.com's Avatar
Wiki Edits: 21
That is the type of head gasket that Chrysler put on the '51 - '53 331 hemi. Replacements are unavailable (thankfully!) so people adapt the more conventional copper/asbestos sandwich type from the later model 345 hemi.
Old 12-28-2004, 09:35 PM
Shim gaskets are not as forgiving of uneven block or head surfaces, so make sure yours are flat before you use one. They work fine, in fact GM used them for years, but theirs are a little thicker (0.026").
